60k maintainance suggestions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2005, 07:27 PM   #1 (permalink)
View toydon's Photo Gallery
Hi
I have a 1997 camry with 60k original miles. It runs good and going to have a 60k checkup. I am wondering particularly about the timing belt if it should b replaced and what to expect cost-wise. It is the 4 cyl. And any other items to be concerned about at the 60k mark.
Thanks
toydon is offline   Reply With Quote
Old 08-08-2005, 11:35 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
At 60k miles it is possible you will have to replace the water pump, cam seal crank seal, tensioner and idler. I said possibly. FI you are in there having the timing belt replaced jsut make sure they check all of taht stuff. As far as price I know here in Middle Tennessee you can have the belt only done for about 200.00 or so at the dealer, they are always sending out coupons for it it seems like. If you have all the other stuff done you are probably looking to get in to the high 400's to low500's. There again guessing. I just had the water pump, timing belt, cam seals, nad crank seal replaced on my 94 V6 and the total bill would have come to about 460.00 or so if my warranty didnt cover it. As far as any other maintenance jsut your normal fluids and filter changes. Maybe spark plugs, fuel filter, trans service, coolant drain and refill or flush. Chekc your local dealers ebsite and see waht you can come up with as far as coupons, like I said our local ones are always running ads for that kind of stuff.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 08-08-2005, 11:47 PM   #3 (permalink)
View bassthrive's Photo Gallery
for my 60k service i did....
plugs and wires
transmission fluid flush (not drain/fill)
oil and filter change
new pcv valve
radiator flush
cleaned battery terminals
air filter service (k&n)
fuel filter (not really necessary at 60)
throttle body cleaning
seafoam treatment
you can do almost all of these yourself and save a ton of money.
now with 100% more clickability
bassthrive is offline   Reply With Quote
Old 08-09-2005, 12:15 AM   #4 (permalink)
Gameroom cash: $155605
View redgtxdi's Photo Gallery
Ya, the timing belt is the big one. Most everything else is fairly easy, but taking that whole front cover off and doing the timing belt is a whole nother deal.
I'd say that since yours is a '97, you're right there on miles (my '98 belt started slappin' the guard at about 80,000) and you're a year older than mine so considering that the belt is aged, I'd say it's good time to get all that stuff done. Do exactly what was listed above.
Belt
Water pump
thermostat
Cam seal
Crank seal
Flush/fill entire cooling system & make sure they put Toyota RED coolant back in there to get off to a good start with your new pump & thermostat. (Trust me when I say that they won't unless you tell them to and I think it's a travesty that regular green coolant is even allowed into a Toyota dealership, but they are as slimy as the next dealer so you have to watch your own ass)
That should about do it. Once all those are done, that front cover doesn't have to come off again for at least another 60,000 miles. You'll have great peace of mind and your only other concern for a long while will be fluids.
You can have 'em check your regular belts & hoses too, but you're probably still fine 'til about 100,000 on those. You can have 'em change 'em or not, it's up to you.
redgtxdi is offline   Reply With Quote
Old 08-09-2005, 01:59 AM   #5 (permalink)
Night Speed's Avatar
View Night Speed's Photo Gallery
i just did my 60k service today. dang... it cost $414 i think i got rip off
i don't think the mechanic check my PCV valve. so how can i check it my self?
thanks
Night Speed is offline   Reply With Quote
Old 08-09-2005, 02:06 AM   #6 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
that's it......i'm seafoaming my sister's avalon. she just hit 60K and she's just doing the regular oil change, fuel injector cleaner.
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 08-09-2005, 02:10 AM   #7 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397685
View RningOnFumes's Photo Gallery
thanks
first take it out...it goes from the top of your valve cover to your intake plenulum *however you spell that*
and just give it s minor shake, it you still feel someting lose and clinking around...it still good. Another test is blow through it and the little hose...you should be able to pass air through it
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
