V6 Camry Manual Transmission??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2005, 09:04 PM   #1 (permalink)
REAPER STRAIN's Avatar
View REAPER STRAIN's Photo Gallery
3rd Generation V6 Camry Manual Transmission???
I have been looking but cant seem to find the answer to this question.
Which manual transmission does the 92-94 Camry come with? I have seen ppl doing this upgrade but havent seen which tranny they used. Because the tranny option was so rare I cant find any reference to it in the Haynes manual or the Toyo Service Manual.
I know is it not the same manual transmission that is used for the I4 but I cant find any other reference to any other camry manual transmission. Please help.
thanks
REAPER STRAIN is offline   Reply With Quote
Old 08-09-2005, 09:11 PM   #2 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
E153 for a V6
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 08-09-2005, 09:18 PM   #3 (permalink)
Hey thanks. Can you tell me a lil more about this tranny? Whether its used in another car. What other parts I may need if I wanted to do a swap.
thanks again
Old 08-09-2005, 09:24 PM   #4 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
its used in the V6 camry and the toyota MR2. It has a limited slip differential, which the 4 banger tranny does not. Its a five speed.
Old 08-09-2005, 09:39 PM   #5 (permalink)
thanks for the info...
Ratko's Page answers most questions
http://www.tt-cc.com/ratko/swap/
Old 08-10-2005, 07:40 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
E153 in a Camry does not have a LSD. You can buy a aftermarket one though (Cusco, Kaaz, Quaife).
E153 in MR2 Turbo is available with LSD.
Tranny from MR2 won't work as is though. It needs to be modified.
http://www.geocities.com/zegoat2000/e1531.html
"Skoolin' the unlearned!"
Old 08-10-2005, 09:27 AM   #7 (permalink)
Can't Touch This
View toyocamry's Photo Gallery
So ur saying my 93 3vz-fe spd comes stock with an E-153 tranny? and i wont need to buy one? Took a load right off my hands if thats true.
toyocamry is offline   Reply With Quote
Old 08-10-2005, 09:36 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
^ Yup, you have a E153 tranny.
Old 08-10-2005, 01:48 PM   #9 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
^i wasn't saying there was no work involved, i was just saying its used there (in the MR2).
Old 08-11-2005, 07:01 AM   #10 (permalink)
The Other White Meat
terrastrife's Avatar
shift linkage is on the wrong side, you can get away with a fwd housing. also although the bolt pattern is the same, there are less bolts on the camry engine (i think)
the e153 shares quite a bit with the r154 which is a rwd version which comes in lots of toyotas so yeah, youre all good to go for making a 1000hp gearbox :P
terrastrife is offline   Reply With Quote
Old 08-13-2005, 11:26 AM   #11 (permalink)
View AdamS's Photo Gallery
hmmm..
thought that the V6 Camry (3vz-fe) came with the E53 not E153. The E153 is the updated version with dual cone synchros...In fact, I beleive that the 3rd Gen camry only offered the E53.
-Adam
1992 3VZ-FE with 218K
Check her out
AdamS is offline   Reply With Quote
