Bosch oem or Toyota oxygen sensor? (o2) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2005, 04:41 PM   #1 (permalink)
View peanutbutter's Photo Gallery
4th Generation Bosch oem or Toyota oxygen sensor? (o2)
My 2000 camry i4 federal is throwing code for the front oxygen sensor. Should I replace it with Bosch oem or Toyota oxygen sensor?
Does the Bosch have problems or not last as long?
peanutbutter is offline   Reply With Quote
Old 08-10-2005, 04:52 PM   #2 (permalink)
View tcma99xtr's Photo Gallery
the only major difference maybe is the cost. and a little bit of performance.
tcma99xtr is offline   Reply With Quote
Old 08-10-2005, 05:19 PM   #3 (permalink)
REAPER STRAIN's Avatar
View REAPER STRAIN's Photo Gallery
go with the cheapest ones you can find. They are all pretty much the same. They can be pretty pricey at times too. OxygenSensors.com is the best place I have found for great selection, great prices and free priority shipping.
REAPER STRAIN is offline   Reply With Quote
Old 08-10-2005, 05:26 PM   #4 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
depends on ur budget..
i would go with Bosch cos it's cheaper
does denso make those sensors cos if so, it might be what toyota put on and rebandage toyo
skewe is offline   Reply With Quote
Old 08-10-2005, 05:48 PM   #5 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
What is bosch running now?
www.1sttoyotaparts.com
OEM yota/denso feds are running $99
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 08-10-2005, 06:49 PM   #6 (permalink)
Thanks guys, Yes I don't care to pay 200 dollars if it will last longer and still get 33 mpg like it was doing before it went south. Guess I'll order a Oem thanks for the link!
Old 08-10-2005, 08:49 PM   #7 (permalink)
View Ranger X's Photo Gallery
I need to get mine replaced too. I'm pretty sure it's the O2 sensors going bad, I'm getting a P0175 code (system too lean left bank). I checked the front one, which I think is the right bank, but regardless I wanted to check it anyway...it gave me intermittent readings. Almost like it was cycling back and forth between open and closed loop. I'll replace both anyway. I have a 1mz though, not sure if there's any difference in the type and amount of O2 sensors. I think maybe the 5s-fe has an a/f sensor in place of one of the O2 sensors or something like that. But anyway, I went to autozone and they told me $110 a piece(!) for the Bosch OE-type sensors, and $60 for the Bosch universal sensors. Which, by the way, require splitting the wires to the connector and resoldering them on to the new sensor. Yuck. So is there anything cheaper than that? And do they last as long?
Ranger X is offline   Reply With Quote
Old 08-11-2005, 07:35 AM   #8 (permalink)
I get code that says running lean bank 1, figure that is the front sensor on a i4.
Old 08-11-2005, 11:07 AM   #9 (permalink)
View Cammy4U2NV's Photo Gallery
can't u get a diagnostic check at autozone for free? to see if the o2 sensors or anything is goin bad by giving u the codes?
Cammy4U2NV is offline   Reply With Quote
Old 08-11-2005, 11:28 AM   #10 (permalink)
Yes sir! The sensor going bad code is usually running lean code, there is no sensor to sense when the sensor is bad.
Old 08-11-2005, 01:06 PM   #11 (permalink)
Retired VW Driver
View d0rkiishchris's Photo Gallery
if you have a VAG u can check urself, or go to a dealer. but, they're going to charge you. Auto-zone and places like that wouldn't be able to check it, atleast the ones around me can't. They're good for checkin the batty... woooOOOOooooOOOO
when the o2 sensor is bad u get your code, and the idle is likely to be rough.
d0rkiishchris is offline   Reply With Quote
Old 08-11-2005, 10:51 PM   #12 (permalink)
Well on a V6, bank one is the one closest to the firewall, or so I think. It's going to be crap to change it out. So just get whatever's cheapest? I figured I'd be able to use one of those universal ones, I'm pretty good with electronics and can solder. It's just going to be a lot more work than I'd like. Anything cheaper than the bosch units?
Old 08-12-2005, 12:36 AM   #13 (permalink)
Green like GIR!
jspec_racing's Avatar
View jspec_racing's Photo Gallery
has anyone replace their o2 sensor by yourself? coz i know i need to replace my but i'm completely clueless about it. and what's the code for and where the heck do you find it??
"Perfection is given, not achieved"
jspec_racing is offline   Reply With Quote
Old 08-12-2005, 06:33 AM   #14 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Take the bad one out and give it a 5 minute burn with a propane torch, then measure the voltage output again to see if it registers porper output.
You shouldn't have anything to lose.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 08-31-2005, 03:37 PM   #15 (permalink)
I found out that I've got a CA emission package on my car. Its a air/fuel sensor not o2, got one for 165! List was 380
