Need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2005, 01:12 AM   #1 (permalink)
Ferrat
Ferrat's Avatar
View Ferrat's Photo Gallery
Need help
I found this pic before and need to find out whos car it is?
[img]http://img357.imageshack.us/img357/8...120052a8pc.jpg[/img]
1989 Camry SV22 (RIP) Blown Motor
1988 Camry SV21
2001 Camry MCV20 V6 Touring
Ferrat is offline   Reply With Quote
Old 08-11-2005, 08:15 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Some guy in Australia owns that car.
Its the same car that was described in this thread:
http://www.toyotanation.com/forum/t91761.html
"Skoolin' the unlearned!"
Old 08-11-2005, 08:48 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
now why would you NEED to find out whos car that is?
mmmmmm crispy clean blower.
terrastrife is offline   Reply With Quote
Old 08-11-2005, 05:48 PM   #4 (permalink)
Ferrat
Ferrat's Avatar
i want to find the guy, coz i have a simular engine :P and i want to supercharge it
1988 Camry SV21
Old 08-11-2005, 08:48 PM   #5 (permalink)
why not turbo? would be easier
Old 08-11-2005, 10:14 PM   #6 (permalink)
Ferrat
Ferrat's Avatar
the reason why not turbo, is actually coz its harder to put in the my gen camry, and to much work for the same gain as a s/c, that bolts straight into the engine
1988 Camry SV21
Old 08-11-2005, 10:27 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
A turbo bolts on pretty easily.
You can use the stock turbo manifold from a 3S-GTE and a Toyota CT26 turbo.
Plumbing it into your carb would be an issue. I don't know much about carbs, other then carbs on r/c car engines.
Pic of my turbo 3S-FE:
^ 3S-GTE turbo manifold, Garrett T3, and custom made adapter.
Old 08-12-2005, 08:47 PM   #8 (permalink)
Ferrat
Ferrat's Avatar
mmm didn't relise a turbo would bolt up that so easy, i'll have to check my carby, see what i need to do, either way s/c or turbo, it'll take some work. What would be the advantage of the turbo?
1988 Camry SV21
Old 08-13-2005, 02:37 AM   #9 (permalink)
its faster then a non turbo?
for the bottom end you can pretty much buy parts, the only real custom bit will be plumbing with the carby.
the real advantage is that its basically bolt on, i bet that guy from aus with the centrifigal blower spent a fair whack on making a bracket -- and then ya gotta find the right belt and pulleys not to mention its doing NOTHING in that picture
Old 08-13-2005, 02:57 AM   #10 (permalink)
Ferrat
Ferrat's Avatar
would anyone be able to give me a basic parts list so i can begin planning?
coz i think it'll be a good project car, plus a one of the kind turbo carby camry hehe
1988 Camry SV21
