Spark Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2005, 09:35 AM   #1 (permalink)
Retired VW Driver
View d0rkiishchris's Photo Gallery
4th Generation Spark Plugs
I figure since most things on my 98 2.2L Camry LE were stock I should go ahead and change my plugs and wires. My Passat had denso iridium plugs put in it and I did actually notice a performance change. Just curious which plugs people got and as to what you all found with your replacement spark plugs.
d0rkiishchris is offline   Reply With Quote
Old 08-11-2005, 10:12 AM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
double tip platinium
what the toyo dealers and toyo part ppl suggested
skewe is offline   Reply With Quote
Old 08-11-2005, 10:36 AM   #3 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
I used denso platinum's (would have used denso iridums if i was supercharged).
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 08-11-2005, 08:58 PM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
the cheapest ngk's that fit :P
theres no point using plats to try to save money, you SHOULD BE taking them out to clean/gap them when youd change normal plugs anyway.
terrastrife is offline   Reply With Quote
Old 08-11-2005, 09:03 PM   #5 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
I recomend you that you use NGK plugs because they are recomende for toyota's.(atleast that's what i was told at kragen) and since i installed mine the engine fires great.
V6LE_CAMRY is offline   Reply With Quote
Old 08-11-2005, 09:04 PM   #6 (permalink)
V6LE_CAMRY's Avatar
Oh and forgot ot menting to buy a gapping tool and gap them to what they are suppose to and torqe the plugs to 13 or 14 foot pounds. (if you have a tourqe wrench).
Old 08-11-2005, 11:09 PM   #7 (permalink)
SiennaSC98's Avatar
View SiennaSC98's Photo Gallery
Yes, I'm using the TOYOTA (Denso SK20R11) Iridium sparkplugs, P/N 90919-01210. These are the 0.70 mm electrode tip rated at 100K miles.
SiennaSC98 is offline   Reply With Quote
