tire pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2005, 01:57 PM   #1 (permalink)
View mendozer's Photo Gallery
3rd Generation tire pressure
hey ppl,
the new rims i got are on semi flattened tires. what should i inflate the tires to? i checked the sticky for tire pressure but its not there. also, i got a 95 so stock is 15 inches, while these are 16 inch rims. (tire size is 205/55/16) i believe (if not its 65/15, opposite of stock). what shud my tire pressure be? 2 of the tires are at about 25 lbs, ones at 12, one doesnt push teh tire gauge out at all haha.
thanks in advance
mendozer is offline   Reply With Quote
Old 08-11-2005, 02:15 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397685
View RningOnFumes's Photo Gallery
did you check the actual tire markings also?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 08-11-2005, 02:23 PM   #3 (permalink)
tire markings? they have the pressure on the tire? i have crappy eyes i cant read that small lol
Old 08-11-2005, 02:26 PM   #4 (permalink)
Ninja-rator
lol...i did you say you got some aftermarket wheels and tires?..then i'm guessing you'll have to follow the pressure stated on the tire.....
......lol...how good are you with the neighbors? grab a kid and ask them to read it for you.
Old 08-11-2005, 03:13 PM   #5 (permalink)
Moving Forward
View Cyorke's Photo Gallery
you can probably keep tham at about 30psi like you would your stock ones. You dont want to use the pressure on the side of the tire since that is max pressure. You are only really going to use max pressure when you have the car loaded to capacity with either riders or cargo. Most of the time the max pressure is somewhere around 50psi and if you run that you will probably not like the way the car rides. Keep it around 30 and you should be fine.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 08-11-2005, 03:18 PM   #6 (permalink)
would it matter that i got 2 different pairs of tires? 2 of em are defender sport HRXs and 2 are Lemans HR. or shud i do both at 30?
Old 08-11-2005, 04:12 PM   #7 (permalink)
Moving Forward
doesnt matter about the manufacturers jsut run them at 30 -32 psi and you should be good if it seems to hard a ride then you can take a little out if it seems to soft add a little bit to them.
Chris
Old 08-11-2005, 04:41 PM   #8 (permalink)
View Cammy4U2NV's Photo Gallery
usually like cyorke said...30-32 PSI is a pretty standard measurement for tires (at least non-low-profiles)...
Cammy4U2NV is offline   Reply With Quote
Old 08-11-2005, 06:13 PM   #9 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
Recommended tire pressure is listed in the drivers door sill.
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 08-11-2005, 06:49 PM   #10 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
look on the door.
if not, read the manual
skewe is offline   Reply With Quote
Old 08-11-2005, 06:55 PM   #11 (permalink)
i checked the door just now. all i saw was this bar code thing and that didnt say anything about pressure.
Old 08-11-2005, 06:56 PM   #12 (permalink)
skewe's Avatar
check the other door
Old 08-11-2005, 07:05 PM   #13 (permalink)
Ninja-rator
arrgh....
manual says:
220/ 2.2 / 32 kPa/ kgf/cm cubed / psi ---respetively
those are for stock 205/65r15
i say stay over 30 and don't go over 45...you 'll avoid underinflating and over inflating...just ride according to the way you want it ie fill to your comfort--the more it is filled the more harsh.
and i still say since they arn't stock, you should at least consider what the tires say
Old 08-11-2005, 07:08 PM   #14 (permalink)
Moving Forward
go with 32 and jsut keep an eye on them to make sure you dont start getting some really weird wear patterns and things like that. You will be fine at 32.
Chris
Old 08-11-2005, 07:11 PM   #15 (permalink)
gas stations have those tire pumps rite?
