reverse glo gauge problem... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2005, 07:08 PM   #1 (permalink)
View chinkywoo's Photo Gallery
some of ya'll mite hate me on this...but i'm having problems installing my reverse glo gauges on a 99 camry. i've connected everything, but once i got to the point of the red wire, i just dont know what to do with it. i know the black wire is supposed to be connected to a ground source, and the instructions says the red wire has to be connected to the power source for like the parking lights or something. anyway, i've tried some things out and no success. any ideas on where i'm supposed to connect the red wire to? or exactly where? thanks
chinkywoo is offline   Reply With Quote
Old 08-11-2005, 07:32 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Connect it to the parking light wire. Its a green wire on one of the plugs going into the back of the gauge cluster.
If you use a DMM to test/verify the wire, you'll see +12V on that wire whenever the parking lights are turned on.
http://www.toyotanation.com/forum/t59805.html
"Skoolin' the unlearned!"
Old 08-11-2005, 07:50 PM   #3 (permalink)
do u know exactly which green wire? and which plug? i've tried 2 of the green wires on the brown plug...and no go
Old 08-11-2005, 07:53 PM   #4 (permalink)
View Cammy4U2NV's Photo Gallery
how exactly do u splice a wire...im about to start my install of my reverse glow gauges and need to splice the power wire into one of the wires going into the back of the gauges...
Cammy4U2NV is offline   Reply With Quote
Old 08-11-2005, 08:15 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
I'm not sure. I just know the parking light wire is green.
Clip the parking light wire, strip (1/4" - 3/8") some of the insulation off each wire, and connect everything together with a crimp connector (insulated butt connector).
Or carefully (you don't want to cut the wire, just remove the insulation to expose the wire) remove a section of the insulation from the parking light wire, wrap the power wire from the indiglo gauges around it, solder it all together, and wrap it with electrical tape.
Old 08-11-2005, 08:28 PM   #6 (permalink)
u dont remember which green wire of which plug to connect it to?
