SAFC2 Installation Help (Wiring Expert Needed!)
Ok, i'm just working out the wiring for my SAFC2.
I have the wires identified, but I would like someone to scan over them, just to make sure they are correct.
Car is a 1988 Toyota Camry V6, VZV21. 2VZFE engine.
It's a standard SAFC2.
SAFC2 WIRE ECU
+12V B
GND1 G- (brown, closest to ECU)
GND2 G- (black, about 1cm away from GND1)
RPM IGF (same wire I used for my shift light)
TPS VTA
KNOCK xNOT USEDx (i don't have a knock sensor)
AFM Output VS
AFM Input From AFM (same wire that goes to VS)
From what I can tell, that is correct, but need some input.
Any help would be nice.
Thanks.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
