Power Windows sticking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2005, 02:08 PM   #1 (permalink)
Registered User
View qprint's Photo Gallery
When opening anyone of my power windows, I hear a thump and I know its sticking and I dont know why it does this. I don't want my window motor going on me because of a power surge.
It doesnt matter if outside temperature is Cool or Hot. Top 1/2 inch of each window has a film on it and I've scraped it off and it still sticks.
qprint is offline   Reply With Quote
Old 08-12-2005, 02:17 PM   #2 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
sounds like a loose electrical connection. first check you fuse.
V6LE_CAMRY is offline   Reply With Quote
Old 08-12-2005, 08:33 PM   #3 (permalink)
5sp 3VZ-FE
mescalito's Avatar
View mescalito's Photo Gallery
possibly the regulator - it shouldn't normally fail that new, but could be malfunctioning.
mescalito is offline   Reply With Quote
Old 08-13-2005, 07:37 PM   #4 (permalink)
View steve97's Photo Gallery
Think about trying a little grease along the rubber gasket of the window channel? Might keep it from sticking, and if it doesn't work, wipe it off.
steve97 is offline   Reply With Quote
Old 08-13-2005, 08:56 PM   #5 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Is it cool to use white lithium grease on the rubber track sections? I need to lube mine up as well but what should I use. I dont want it to eat the rubber up?
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 08-14-2005, 12:09 AM   #6 (permalink)
View toyo_tech02's Photo Gallery
yeah the top of the window is sticking in the moulding, get some rubber care and apply to the moulding, it softens and moisturizes the rubber, it will take care of your problem.
toyo_tech02 is offline   Reply With Quote
Old 08-14-2005, 12:24 AM   #7 (permalink)
Toyota Addict
briangk_77's Avatar
View briangk_77's Photo Gallery
What do you mean by "rubber care"? Is this an Armor All like product or something different. Basically, I have this same issue and would like to know the specific product to purchase from AutoZone.
Thanks much.
briangk_77 is offline   Reply With Quote
Old 08-14-2005, 08:54 PM   #8 (permalink)
actualy im not exactly sure where you would get it, we get ours from the worth vendor, you might try using mink oil. avaliable at walmart or just about anywhere.
Old 08-16-2005, 09:53 AM   #9 (permalink)
Registered User
Lithium is more common solution, I think
