roughg idle and missing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2005, 05:32 PM   #1 (permalink)
View emeny2's Photo Gallery
3rd Generation roughg idle and missing
before u bash me for posting i couldnt find any threads to help me out.
i have a 92 cam with the 5sfe and a 5 speed. my car suddenly started to idle at 250-500 rpm and sometimes when i try and accelerate it kills unless i let off. i also noticed that my fuel comming out of my filter is black! and my engine bucks so much i have already replaced my front motor mount twice. 2nd time it broke egr valve was smacking the firewall and cut a vaccum line in half (replaced line) but motor still runs like crap any help is much appreciated.
gonna miss tn once my camry is gone
emeny2 is offline   Reply With Quote
Old 08-13-2005, 05:47 PM   #2 (permalink)
View Cammy4U2NV's Photo Gallery
u might search "seafoam" for the seafoam treatment...i know that has helped my idle/running a pretty noticeable amount...also try the "throttle body cleaner" thread too...
Cammy4U2NV is offline   Reply With Quote
Old 08-13-2005, 05:51 PM   #3 (permalink)
throttle body been cleaned with no change
Old 08-13-2005, 07:15 PM   #4 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
fuel injectors dirty?
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 08-13-2005, 07:42 PM   #5 (permalink)
View camlex's Photo Gallery
fuel filter?
camlex is offline   Reply With Quote
Old 08-13-2005, 08:51 PM   #6 (permalink)
View Leinad's Photo Gallery
Is your 92 equipped with an EGR valve ?
Bad EGR valves makes for a rough idle.
Daniel.
Leinad is offline   Reply With Quote
Old 08-14-2005, 12:30 AM   #7 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
black fuel?
change the filter? also there another 2 filters in the tank you might want to look at. a mesh for the pick up an another for the fuel return. also look at IACV cleaning.
^ and leaving it that way!
Old 08-16-2005, 06:00 PM   #8 (permalink)
the egr hitting the firewall might have messed that up i have new fuel pump w/ pre-filter in there. might try changing fuel filter again cause its probably plugged up. thanks for advice on those.
chronoti what is the IACV?
Old 08-16-2005, 07:03 PM   #9 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
Check the inside of the rotor/ distributor for worn out points. check for bad plugs, air filter and clean/check IAC motor.
V6LE_CAMRY is offline   Reply With Quote
Old 08-16-2005, 07:43 PM   #10 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
There's no such thing as an IAC motor (idle air control valve... motor )
although you hit money with stating check the IAC.
Spray some throttlebody cleaner on the IAC valve, check your ignition timing and spark plugs. Changing your air and fuel filters would be beneficial.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 08-16-2005, 09:40 PM   #11 (permalink)
View Calvin327's Photo Gallery
checking and replacing that little PCV valve will also be beneficial...usually that's one of things that are left forgotten.
Calvin327 is offline   Reply With Quote
Old 08-16-2005, 10:50 PM   #12 (permalink)
V6LE_CAMRY's Avatar
That's what i wanted to mean , isn't there a way to test that idle air control by bridging two connection on the diagnostics port? i think it says in thye Haynes manual.
Old 08-17-2005, 07:00 PM   #13 (permalink)
Zzzz
The IAC valve may let your car run 'smoother' but it shouldn't make it buck or anything. An afterthought on this would be if it's doing it only when driving, it's likely the simple answer: the clutch
-mark
