Camry transmission problem... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2005, 08:45 PM   #1 (permalink)
View Leinad's Photo Gallery
I wondered if any of had this problem.
My 98 camry is equipped with an automatic trans. On a cold start, even in summer, the trans take about 10 to 15 seconds to engage in the drive position.
Once the car has runned in the day, there is no more problem.
I changed the oil...no diffrence.
I'm leaning toward a faulty valve or pressurising device of some sort .
Any ideas.
Leinad is offline   Reply With Quote
Old 08-13-2005, 08:46 PM   #2 (permalink)
Oh yah....thanks.
Old 08-13-2005, 08:50 PM   #3 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Mine as a similar problem, If the car has sat for awhile and you put it in drive, it wont start to creep forward for like 10 seconds. If you give it gas it will just rev up and sit there. But after a few seconds it starts to move. It all happend after I had the tranny fluid flushed. I am doing a tranny swap in a week or two so Im not to worried though. I wouldnt worry to much about it.
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 08-13-2005, 09:59 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Is the fluid level correct? start car, open hood and shift through all gears from P to 1 and then back to P.
with engine running check trans fluid level.
If OK,
Drain and fill your fluid. It happened to my 4cyl last summer, and that solved the problem.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 08-13-2005, 10:42 PM   #5 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
well, there's always SeaFoam TransTune. Worked for me when my gen2 had the same problem.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 08-14-2005, 06:40 AM   #6 (permalink)
The oil level is fine.
I'll do a search for the sea foam " thing".
Thanks to all.
Old 08-14-2005, 07:07 AM   #7 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $912627
iTrader Score: 59 reviews
Ya my 3.5 has had simular symptoms in the past, I didn't do anything about it and it just stopped doing it for now. I've never heard of seafoam for transmissions, I'll have to check that out too!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 08-14-2005, 07:33 AM   #8 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
from the toyota manual
fluid pressure is low
forward clutch is bad
o/d clutch is not working right
when you dump the old fluid change the filter and clean the pan see if that helps. also maybe a tranny flush.
^ and leaving it that way!
Old 08-15-2005, 01:01 AM   #9 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
i said on an earlier post...basically i had the same thing on my- '92 V6XLE- you wouldnt feel the little pop forwards, and it would creap until i revved it to like 2.5, 3 grand and then pop and go. i got the tranny swapped- no problems now.
Axel Kain is offline   Reply With Quote
