Is this any good - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2005, 07:20 AM   #1 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
Is this any good
Saw these rotors while searching for rims, and now it has peaked my interest seeing as how i want the car to STOP not yield.
http://cgi.ebay.com/ebaymotors/Toyot...92817222QQrdZ1
Would they work on my 02 Camry LE 15"x5" rim, are they any good, or am i better off purchasing something else?
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Old 08-14-2005, 07:33 AM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
i would get some brembo.
regular brembo does just fine.
about $100 + for cross drilled
would not buy that ebay brand
skewe is offline   Reply With Quote
Old 08-14-2005, 02:21 PM   #3 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
r1 concepts <~~~ ebay seller sells OEM rotors that are drilled/crossdrilled.
check them out. i think that's where Mikey21 got his.
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 08-14-2005, 02:46 PM   #4 (permalink)
Dominican Republic
Dj-torn's Avatar
found them.. but got a noob question... doesn't more stopping come from a bigger brake b/c of more surface area making contact w/ brake pad? or am i just making stuff up?
I will buy them if they are garanteed to be better than stock & will improve my stopping distance from 60-0 by at least 5-10ft.
Old 08-14-2005, 02:54 PM   #5 (permalink)
The Cool Guy
better pads can help you stop faster, but a bigger brake setup would give you a better stopping power...
Old 08-14-2005, 03:20 PM   #6 (permalink)
Dominican Republic
Dj-torn's Avatar
nabit!, gotta get rims if i want bigger brakes... well did Mikey21 get the OEM brakes, if so what does he have to same about them? (assuming you are friends)
Old 08-14-2005, 03:27 PM   #7 (permalink)
The Cool Guy
haha we don't know each other like that but he says he got the ones that i'm guessing. R1concept sells.
which like i said...OEM brakes but just drilled and crossdrilled
Old 08-14-2005, 03:52 PM   #8 (permalink)
Dominican Republic
Dj-torn's Avatar
just to verify, that i saw what you were talking about;
http://cgi.ebay.com/ebaymotors/ws/eB...%3A1%3A1v_home
Old 08-14-2005, 04:00 PM   #9 (permalink)
The Cool Guy
the seller is r1concepts
http://cgi.ebay.com/ebaymotors/Toyot...temZ7991870117
Old 08-14-2005, 10:28 PM   #10 (permalink)
Moving Forward
View Cyorke's Photo Gallery
GOing to larger brakes will help your stopping distance. Jsut going to cross drilled and slotted rotors will not necessarily shorten your stopping distanc. It may help a little. Typically when you go to drilled and slotted rotors you are trying to help with heat dissipation. Heat build up is what causes brake fade. You get the rotors hot which boils the brake fluid which causes the fade. GOing to drilled and slotted rotors will help prevent this on the same level as OEM rotors.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 08-14-2005, 10:34 PM   #11 (permalink)
View Ranger X's Photo Gallery
This is a pretty controversial subject on TN from what I've seen...do a search...a lot of the senior members (or just really knowledgeable members) seem to think that cross drilled and slotted rotors won't do anything in a normal application.
Ranger X is offline   Reply With Quote
Old 08-14-2005, 10:40 PM   #12 (permalink)
ECHO....Echo....echo....
BenG's Avatar
View BenG's Photo Gallery
bigger brakes do give you pads with more surface area, but i read somewhere that while bigger pads do help, the majority of the braking increase is from the distance the caliper is from the centre of wheel rotation. Something about how it's easier to stop a spinning object farther from the rotation center because it's moving slower or soemthing like that. A bigger brake rotor also means you have more mass to dissapate heat with.
BenG is offline   Reply With Quote
Old 08-14-2005, 11:05 PM   #13 (permalink)
Moving Forward
^^^ what both Ranger and Ben said. jsut going to drilled and slotted rotors is not going to have a very big if any affect on your stopping distance. It may to soem extent help with brake fade. The only way to get better stopping is to have more braking surface, ie. you need larger rotors and then larger pads to cover more of the rotor along with this you are going to need larger calipers to hold the larger pads and etc etc. and on and on
Chris
Old 08-15-2005, 07:47 AM   #14 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
sloted doesnt cool. it shaves off a little of the surface each time so fresh new pad is mating with the surface.
a cross drilled stock would work almost the same as a brembo but is more likely to crack. big thing with non brembo rotors they have a tendancy to crack and brembo are warrented against cracking.
^ and leaving it that way!
Old 08-15-2005, 01:19 PM   #15 (permalink)
Dominican Republic
Dj-torn's Avatar
I love TN, and from what i have learned, in order to acheive the shorter stopping distance and the best bang for my buck, Would be the ROTORA big brake conversion. Unfortunatly at $1,700 + install... is currently far beyong my budget.
Maybe somebody will wreck their Mercedes/Macleran (i forget what the car is called) so that i can see it in a junk yard and steel its brakes.
"Rear brakes
360 mm ceramic discs, four piston callipers plus airbrake
Front brakes
370 mm ceramic discs, eight piston calipers"
http://images.google.com/imgres?imgu...magesr&start=1
(not that i know what any of that means, i just know that it stops FAST, from 120mph to 0, in the same distance that it take the average car from 60mph-0)
Thank you to all for teaching me,
