Squeaky doors damit! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2005, 08:04 AM   #1 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $912627
iTrader Score: 59 reviews
3rd Generation Squeaky doors damit!
My 3.5 front doors squeak I've tried WD40, 3in1 oil, nothin helps. You guys/gals have the same problem? If so, how did you stop it? any special lube?
Thanks for any solutions. cause its drivin me crazy!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 08-14-2005, 08:13 AM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
wd-30 will not do!
white grease
or marine grease
skewe is offline   Reply With Quote
Old 08-14-2005, 08:35 AM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Originally Posted by skewe
wd-30 will not do!
white grease
or marine grease
Agree WD40 doesn't do jack! How would you get the thick lubes, (white grease) to penatrate the hinge? what just rub it on it. Thanks for the reply
98 Honda CRV
08 GMC Crew
Old 08-14-2005, 08:54 AM   #4 (permalink)
skewe's Avatar
good rub and lots of opening and closing
Old 08-14-2005, 09:18 AM   #5 (permalink)
Super Moderator
eyeball96's Avatar
Thanks, Ha! Kinda the same thing I did with my first Girl friend!......but if it'll work on my doors
98 Honda CRV
08 GMC Crew
Old 08-14-2005, 09:23 AM   #6 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Use some marine lithium grease
http://www.xclusive.bz
Old 08-14-2005, 01:18 PM   #7 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
WD40 worked fine for me. Just sparyed it on the hinges and opened and closed the door constantly and the squeaking stopped. Of course everytime I open the door now it slams right back closed, unless fully open.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 08-14-2005, 01:50 PM   #8 (permalink)
skewe's Avatar
using this is better than wd40 as u do not have to spray it within a few weeks or so.
marine lithium grease or regular white grease will last a long time.
Old 08-14-2005, 03:43 PM   #9 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
I have tried lithium grease, wd40, special oil, but it is true, the low frequency squeek comes back, especially if you do not use the car everday.
mandyfig is offline   Reply With Quote
Old 08-14-2005, 03:53 PM   #10 (permalink)
Moose crossing.......
View Troyfrezze's Photo Gallery
3rd Generation
not to steal the topic here, but since we are talking about the door...does anyone have a clue as to how to tighten the spring mechanism that holds your door open? On my 93 if you open the door, even on level ground the door just swings back at you, the tension bar doesn't hold the door open. Is there anything that can be done to make it so the door stay open?
Troyfrezze is offline   Reply With Quote
Old 08-14-2005, 06:36 PM   #11 (permalink)
View freestylez's Photo Gallery
WD40 works fine for me doors havent squeak yet
freestylez is offline   Reply With Quote
Old 08-14-2005, 11:40 PM   #12 (permalink)
View AdamS's Photo Gallery
Good question, mine does the exact same thing....Anyone else have this problem?
-Adam
1992 3VZ-FE with 218K
Check her out
AdamS is offline   Reply With Quote
Old 08-15-2005, 12:03 AM   #13 (permalink)
Carzz R Xpensive!!111
felkajamine's Avatar
iTrader Score: 11 reviews
View felkajamine's Photo Gallery
-Adam
that's wierd, so what does the tension bar look like? does it look broken, cause i've seen mine uplose with the door off, and it's just two bars that are nutted together in the middle
maybe it needs to be pushed into the housing more, it goes into a slot on the door frame, maybe it got jarred out a little.\
EDIT: is this the part that holds the door open, cause that's that part i was talking about, and it slide back and forth into that slot on the door itself
'95 5spd Scepter Coupe
felkajamine is offline   Reply With Quote
Old 08-15-2005, 12:05 AM   #14 (permalink)
View alxch1n16's Photo Gallery
there is a little o ring on the end of the part that sticks out of the door. ill take pics tomorrow, but make sure the little o ring isnt broken. mine was partially broken, and it would only stay open when fully pushed open, and close any other time. im assuming 3.5's are the same as gen 3s.
alxch1n16 is offline   Reply With Quote
