Drum-to-Disc Conversion Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2005, 04:11 PM   #1 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Gen5 Drum-to-Disc Conversion Question
How much does it cost to do a drum-to-disc conversion? I'm wondering how expensive it is... not sure if its really worth it or not. Will I get a lot more breaking power from having discs in the back as opposed to drums? Thanks.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 08-14-2005, 04:13 PM   #2 (permalink)
cam2Xrunner's Avatar
Price to Performance factor not good. Get Rotora's
Old 08-14-2005, 04:19 PM   #3 (permalink)
HID/Retrofit Expert
Rotora doesn't have anything on their site for the Camry...
Old 08-14-2005, 04:26 PM   #4 (permalink)
View majorgercko1's Photo Gallery
YYeh i head dics have more breaking power, its weird cuz in my cam both are discs front and back.
I dare you to compare...
majorgercko1 is offline   Reply With Quote
Old 08-14-2005, 04:29 PM   #5 (permalink)
HID/Retrofit Expert
That's 'cause you've got an SE... mine is an LE.
Old 08-14-2005, 04:32 PM   #6 (permalink)
oh yeah mines better jk/ (or am i?)
what does se mean and le? second edition? limited edition?
Old 08-14-2005, 04:32 PM   #7 (permalink)
They make them for the Gen5, it's just not listed. I used to work there
The retail is 2,095.00 but I can get TN members 10% off. So figure 1895.00 If anyone is seriously interested PM me and I'll see if I can do any better.
Old 08-14-2005, 04:33 PM   #8 (permalink)
But to answer your original ? Do a search on "Drum Swap" or "Disc Conversion" And filter it to only the Camry section and you'll see a ton of threads on this topic.
Old 08-14-2005, 04:40 PM   #9 (permalink)
HID/Retrofit Expert
Oh you're talking about big brake conversion? haha.. yeah, I don't think I'll do that for a while... I've got other plans on where to drop money first... I was just going to upgrade my brakes and get slotted/drilled rotors, and maybe do a rear disc conversion, and paint my calipers red... but at this point, since you say its not worth it to do a disc conversion (and i'll go do a search about it too), I'll probably just change the fronts and paint the calipers.
Old 08-14-2005, 05:03 PM   #10 (permalink)
REAPER STRAIN's Avatar
View REAPER STRAIN's Photo Gallery
You need a few things to do this. The rear disk assembly (rotors, shoes, and hardware). Then you need the brake cable. This shouldnt run you too much money if you go to the right spot. Around here we have Pull-a-part where you go and take parts off of salvage cars yourself for a low low price. For both sides I paid $60 plus another $15 for the brake cable. Besure to keep all little pieces because it is nearly impossible to find them anywhere else but the dealer ($$$$) or a salvage yard. All in all you shouldnt spend more than $100 for these parts. Chances are everything will be in great working order and you dont need to spend any more money on incidentals like turning the rotors or buying new pads and shoes.
Also, be sure to readup on the process (how-to's and your haynes manual). this will save you time and guess work.
REAPER STRAIN is offline   Reply With Quote
Old 08-14-2005, 05:19 PM   #11 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
Someone did a writeup on a gen 4/4.5 awhile back. I had considered it but ruled it out because I use my car as a DD and its only a 4banger.
I think his parts ran 500-1000 from the junk yard (I think that figure had a built in snafu in case you messed up).
Honestly, a good set of brembo blanks with Hawk HP+ or HPS pads will be more than sufficient for us DD guys--I'm assuming you aren't building a track car right?
Throw some high quality ceramics on the back and you'll be set
2k just aint worth it unless its for show or go.
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 08-14-2005, 05:45 PM   #12 (permalink)
HID/Retrofit Expert
Nah, I'm not building a track car... alright then! Thanks for your input. Guess I'll just get some good front rotors and ceramic pads, and get some upscale rear drums, and be happy. Haha. Maybe in the future, I'll get a big brake kit for the fronts...
Old 08-14-2005, 05:48 PM   #13 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $591657
View xpeed's Photo Gallery
CE = Standard
SE = Sports Edition
LE = Lenient Edition
XLE = Luxury Edition
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 08-14-2005, 05:54 PM   #14 (permalink)
Are you front pads wearing out anytime soon? Are the rotors warped? I wouldn't change anything til you need to. If anything, you can get a more agreesive pad and use your stock rotors, which if they aren't warped, then they're good quality. Might be a good idea to have them resurfaced just enugh to take off the top layer.
There's no such thing as a Drum upgrade Stock is fine.
Old 08-14-2005, 05:56 PM   #15 (permalink)
Originally Posted by xpeed
CE = Standard
SE = Sports Edition
I'm pretty sure it means
LE= Luxury Edition
XLE= Extra Luxury Edition
And CE= Classic Edition
