brake light trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2005, 07:58 PM   #1 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
brake light trouble
brake light problem....
well as simple as a problem as this sounds, i cant make it stop!!! AND ITS ANNOYING.
My brake light occasionally just turns on, its happens more often when i am turning or accelerating. It did this once before and i put new pads all the way around it stopped for awhile and now its doing it again. I looked at all my pads and they are still in very good condition.. WHAT CAUSES THIS PROBLEM... ?!?!?!?!
thanks in advance guys.,
vsixcamry is offline   Reply With Quote
Old 08-15-2005, 08:45 PM   #2 (permalink)
see me commin=run
View NEME5IS's Photo Gallery
check your brake fluid levels... i know that most cars have a sensor in them (ever wonder why there are wires attached to the cap? that is the sensor wires)
1998 (gen 4) toyo camry LE
NEME5IS is offline   Reply With Quote
Old 08-16-2005, 08:53 AM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
sounds like the fluid is low which could mean it is time for pads again or maybe a wheel cylinder leaking. DOnt jsut add fluid to it nad let it go. You should check the front pads for wear and the rears for wear and wheel cylinder problems. Brake system is a sealed system so if it is low those are about the only two things that could cause it.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
