Well...
If the wire snapped off the connector, then you should probably get a new one, or one from the 'yard as has been suggested. It will work fine IF it is the correct connector. That is, if it fits, and the colors of the wires match the old one. If the colors don't match, then it will work only if you match up which wire corresponds to which part of the connector using the old one as a reference.
If the wire broke somewhere after the connector, you can save yourself a bunch of trouble by just splicing the wire back together.
Either way, if you've never done any wiring before, I would get a friend to show you the basics of stripping wires, splicing, and taping (it's really simple), or just get a shop to fix it.
My Camry is blue-ish
