where to run the power wire for an amp on a 99 camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2005, 01:00 AM   #1 (permalink)
View londonandlawson's Photo Gallery
im not seeing any spot
londonandlawson is offline   Reply With Quote
Old 08-16-2005, 01:09 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
from the battery -- FUSE (30-40amp) as close to the battery as possible)
though the firewall (ecu harness hole)
along the door sills (the plastic comes off so you can runit under)
up the underside of the rear seat
and youre in the boot
if you want it in the boot that is...
8 gaugeis fine for less then 200wrms
its a fun afternoon project.. you get to tark apart lots of things
terrastrife is offline   Reply With Quote
Old 08-16-2005, 01:16 AM   #3 (permalink)
ecu harness hole???
Old 08-16-2005, 01:17 AM   #4 (permalink)
follow the wires in ya engine bay -- youll find it
they all go from fuse boxes to ecu under ya dash.
Old 08-16-2005, 06:56 AM   #5 (permalink)
View Dark-LE's Photo Gallery
I found a hole on the drivers side that goes right through the firewall. Its a small hole (about the size of a pencil) that is filled in with some sort of goo (silicone i think). I just pulled all the crap out and used my handy hand drill to make it bigger, and i ran my 4 gauge wire through. Its very easy to get to, just look above the break to the left some, and there it is.
I did what everyone else did as well, i ran it under the trim.
Make sure you keep signal (speaker and RCA) cables AWAY from power lines. I kept all my power lines on the drivers side bottom trip, and my RCA cables on the passanger side. Also, i routed my speaker wires on the top trim to keep the speaker wires completly away from power lines.
My Gen 4 Needle Change DIY
http://www.toyotanation.com/forum/t88355.html
My CarDomain
http://www.cardomain.com/ride/2047254
Dark-LE is offline   Reply With Quote
Old 08-16-2005, 07:07 AM   #6 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
there is a large hole right up in the drivers footwell, ive used it. If you drill a new hole make sure you use a grommet
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 08-16-2005, 07:13 AM   #7 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
6 inches up and left to the brake pedal there is an inch wide hole that i was able to fit 4 gauge through. u will have to temp take out the grommet to be able to fit a decent size wire there.
MrSo0h0o is offline   Reply With Quote
Old 08-16-2005, 10:04 AM   #8 (permalink)
Del The Funky One
Delay_FTB's Avatar
View Delay_FTB's Photo Gallery
Use the pre-existing hole by the brake pedal. It goes through the firewall, into the wheel well, and back out into the engine bay. It might be kinda difficult to get there because you have to take the wheel well lining off to run from the firewall to the engine bay, but its easier than drilling a new hole or anything like that. I can get some pics if you want.
Originally Posted by cam2Xrunner
With a bangin sound system, Carputer with online connection, 1+ lateral G's, and a Twizler Dispenser. That's pimp right there.
Delay_FTB is online now   Reply With Quote
