Originally Posted by lilkevie
can someone accurately explain what a strut bar does a rear sway bar and a front sway bar or something to that nature does .. i know it has to do with bodyrolls but like where do each of there things go and if your car is on stock height does it even matter?
well...I'm no expert, and somebody will elaborate on this later....
basically, all the bars that tie your car together will basically help make your frame more rigid, and cause less flex when you're turning. This will result in better traction on turns by distributing weight to all the tires or something like that....
and if you're running on pure stock suspension right now....best thing to do is to do your springs and struts first.....otherwise, your car will dive into turns and have shitloads of body roll no matter what else (suspension-wise)you do to it.....only thing that may help anyway would be a strut bar...
I just put my strut bar on like, a week and a half ago, and I have to agree with everbody...it's the best bang for the buck....
