Electrical (Rant) - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 08-16-2005, 01:51 PM   #1 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
Electrical (Rant)
So I had a problem earlier about my Driver side rear window not going up but goes down fine. So I take it to a mechanic and he says its the master switches fault.
Hes fuckign around with everything and blows the master switch along with the power roof, dome light, map light, radio and all the other windows......
So we replace the radio fuse so I can at least listen to some music. So as Im driving home I high beam some idiot ahead of me and guess what; every time I use the High beam now, the radio shuts off! HAHAHAHAHA!
SO I buy a new Master switch for 50 bux and replace it and everything works fine. But that window STILL dosn't go back up........
......back to square one and Im $50 poorer......
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline
Old 08-16-2005, 02:18 PM   #2 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
Don't you wish there was an OBDIII which troubleshooted all of the electrical faults in the vehicle?
Keep is offline
Old 08-16-2005, 02:47 PM   #3 (permalink)
MOUTH SLAP!
U betcha man. Electric problems r tricky to diagnose and spread like wild fire if u mess with a fuse or switch.
Old 08-16-2005, 03:04 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ I would check the motor/regulator in the door. And the wiring going inside the door.
Sometimes the wiring going into the door gets messed up.
"Skoolin' the unlearned!"
88 LE is offline
Old 08-16-2005, 04:10 PM   #5 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
if the window switch is good and the window does in fact move, then you know the wires are intact... it has to be the motor that is bad...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline
Old 08-16-2005, 06:22 PM   #6 (permalink)
MOUTH SLAP!
The motor and switch are fine. The motor is capable of going up and down. In order for the motor to put the window up u have to pull on the wiring that leads from the door to the chasis while lifting the switch up.
Theres a break in one of the wires, Im sure of it. But when we tested the wires they all seemed to work.
Old 08-16-2005, 09:32 PM   #7 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
As 88 said ,they break at the point where they flex in that little area between the door and the body. The wire can be broken inside even though the outer insulation looks good. See this all the time at work.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline
Old 08-16-2005, 10:20 PM   #8 (permalink)
MOUTH SLAP!
We tested each wire with this little gizmo that pokes into the wire and detects if theres a current and how weak/strong it is. All the wires checked out fine
Dammit!
Old 08-16-2005, 10:42 PM   #9 (permalink)
View alxch1n16's Photo Gallery
hmm..ill have to take a look at this, unfortunately in madison two door master switches are hard to come by...at least any place i check out they're uber expensive, and i think i might have fried mine. so if it is the wiring, like you said shawn and le88, that'll save me some money!
alxch1n16 is offline
Old 08-16-2005, 10:46 PM   #10 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Dammit!
Hmm, maybe you should check all your wiring? Sounds like a bad wire.
OK, maybe it's simply just the plug going into the master switch. Since you're probing the wires probably from the plug, then possibly one wire in the plug came loose, or was burnt out, or something....
Silver Streak is offline
Old 08-17-2005, 05:04 AM   #11 (permalink)
I'm a Mac
zoni's Avatar
rewire the whole car!!!! thats what toyota would do! 900 dollar chassis harness, new power window motor, new master switch, etc.... LOL @ stealership.
Dave Zoni
zoni is offline
Old 08-17-2005, 09:00 AM   #12 (permalink)
MOUTH SLAP!
OMG. Thanks for the scare Dave. BTW, hows your car doing? Your site has NO updates as usual and u stopped coming to the meets. You think your too good for us huh?
Anyways, back to the car. We checked EVERY single wire today and still found nothing. ALL the wires WORK! Even the ones underneath the dash and all the switches work fine too! WTF is the problem then? This is pissing me off now.
Old 08-17-2005, 09:01 AM   #13 (permalink)
MOUTH SLAP!
If you want, I still have my old one that I can sell you. Im rebuilding it. Give it to ya for cheap and if it dosn't work u can send it back and Ill refund your money.
Old 08-17-2005, 04:03 PM   #14 (permalink)
I'm a Mac
zoni's Avatar
stopped coming to the meets? has luis been there? i go where he goes... he goes where i go... p.s. you guys didnt come up to connecticut when i had a meet here... do you know if we get the whole new york crew, and the whole mass/NE crew together, we could have a decent like 30 cars... at least. you bitches were too afraid to come to CT forget going to canada... canada was AWESOME! sweet meet. like 50 cars man. you guys just are afriad to drive. people from st louis drove 14+ hours straight or something...
Dave Zoni
zoni is offline
Old 08-17-2005, 06:11 PM   #15 (permalink)
MOUTH SLAP!
Us NY people get lost outside of NY
a few meets ago we had a meet in Long Island, a bunch of cars came out. Like 20-30 of all makes and brands.
Closed Thread
