Cam springs noise? Valve tapping? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2005, 11:30 PM   #1 (permalink)
trioptimum's Avatar
View trioptimum's Photo Gallery
Hey all; had a clicking/rattling noise in the engine recently, dealer took a quick look and said it's probably the cam spring needing repositions/adjusted, they said it looks like someone had taken off the cover and didn't put it back together right.
Can this spring problem make a noise as such or is there anything else it could be? Is $80 (1hr labor) and ~$20 in parts a decent price for this?
I was suspecting the idler pully or something timing belt related before but they seemed pretty certain it was the spring problem.
Thanks!
trioptimum is offline   Reply With Quote
Old 08-16-2005, 11:34 PM   #2 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
They are talking about a valve spring, is it really loud and under wht conditions does it make the noise?
V6LE_CAMRY is offline   Reply With Quote
Old 08-16-2005, 11:36 PM   #3 (permalink)
trioptimum's Avatar
Yeah I got 4 hours of sleep today so I'm confusing terms already :P. It's pretty loud with the hood open, but inside the car it's not audible. It increaes in pitch and speed (frequency) slighty when revved up I think.
Thanks .
Edit: Is this reffered to as valve tapping? I think this post below is the same problem I'm having, my mechanic mentioned shims to adjsut it. Sorry I'm so confused, it's been a confusing week of car terms being thrown at me constantly .
http://www.toyotanation.com/forum/t88592.html
Old 08-16-2005, 11:54 PM   #4 (permalink)
V6LE_CAMRY's Avatar
Yea that's the kind of tapping im talking about, is that what you think it is?
Old 08-17-2005, 12:31 AM   #5 (permalink)
trioptimum's Avatar
I think it's either the valve springs need adjusted/repositioned as the dealer said, or the valve clearance needs adjusted using shims as my mechanic said. I don't know which one it is. Neither of them opened it, they were just guessing by the noise.
Would it be possible for the mechanics to tell which on it is once it's open?
Thanks for your help.
Old 08-17-2005, 07:25 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You can't adjust the valve springs. If their out of spec, you replace them.
What you can adjust is the valve lash / valve clearance. Checking the valve lash is not a big deal. Adjusting it is a pain in the ass since its a shim on bucket design.
"Skoolin' the unlearned!"
Old 08-17-2005, 10:11 AM   #7 (permalink)
trioptimum's Avatar
Hmm; could it be the springs aren't seated properly or something? They mentioned someone putting the valve cover back on without putting in / seating the springs properly, causing the noise.
In either case, will they be able to tell if it's the springs or valve clearance when they get in there? Or will it cost me more than an hour's labor?
Thanks!
Old 08-17-2005, 08:13 PM   #8 (permalink)
Grenaded piston
88 LE's Avatar
No way. Unless your motor dropped a valve or something, in which case you'll be hearing more then just a tapping sound.
The valve springs just don't magically come unseated.
Wrong.
The valve cover is just a cover. It has nothing to do with the valve springs other then covering them up.
Do me a favor and go smack that person upside the head for being stupid.
If your getting valve tap its most likely because:
1. Valve lash is out of spec.
2. Worn lifter bucket.
3. A combination of 1 & 2.
The Following User Says Thank You to 88 LE For This Useful Post:
AlmightyCamry777 (03-18-2011)
Old 08-17-2005, 08:22 PM   #9 (permalink)
trioptimum's Avatar
Yeah, I went back to the dealer today, when they handed me the papers to sign the estimate had changed from $40 to fix it to $300 to look at it and addittional to fix it ><. So, last time I go there.
Goodyear is going to take a look under there and see what's wrong for $40 flat fee, no charge if they don't find anything, so that sounds good to me. I think it's got to be the valve lash needing re-speced... they just stick shims under there, right? Waht can I expect to pay for that, and should the timing belt be done as well then? (it's got a good 20k before it _needs_ done, but if labor is overlapping, might as well).
Did someone likely abuse this car if that's the case ? I'm thinking I should get rid of it and get a different Solara if this one was beat up on or not maintained. It's been a pain in the ass so far (o2 sensor, EGR position sensor, airbag computer, and this, all in 4 weeks, car ran and checked out FINE when I bought it a month ago - this car is being worse than my nightmare Saab was ).
Thanks guys .
Old 08-17-2005, 08:33 PM   #10 (permalink)
trioptimum's Avatar
Also, see here:
http://www.toyotanation.com/forum/t79935.html
One guy towards the bottom mentions the spring coming loose and rattling in the cover. That's probably what the mechanics were talking about.
Damnit, I hate cars when they make noises and cost money. I need to be a mechanic just so I can get this frustration of not knowing what's wrong with my cars out of my life :P.
Old 08-17-2005, 08:54 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
Its more involved then that.
1. Check valve lash on all valves with a feeler gauge. Note any that are out of spec.
2. Remove the shim from the valves that are out of spec. This requires special tools.
3. Measure the shim with a micrometer and note thickness.
4. Replace all the shims that were removed with shims of the proper thickness.
5. Check valve lash again.
A lot of work.
No idea what it would cost to adjust the valve lash. I do everything myself because I don't trust shady mechanics.
You can hold off on the timing belt for now.
Thats the spring on the camshaft. Totally different part then a valve.
And its a different motor (3S-FE).
Old 08-18-2005, 12:27 AM   #12 (permalink)
trioptimum's Avatar
I have no idea what spring they were talking about . Ehh... yeah, that's where the $300 quote came from then, that is a bit of work. I just hope it doesn't cost allot of money when it's over with. Thanks for the reference; I'll post back when I know what it was, hopefully Goodyear can do it on the cheap - I can do allot of stuff myself on this car, but not engine related things. Thanks again for all your help.
Old 03-10-2011, 11:53 PM   #13 (permalink)
View turblown's Photo Gallery
I know this thread is beyond dead, but did you find a solution to your noise problem?
turblown is offline   Reply With Quote
Old 07-22-2011, 12:39 PM   #14 (permalink)
trioptimum's Avatar
The cam springs had to be replaced; someone had rebuilt the engine by hand (using silicone instead of seals) and put it together incorrectly. Cost me about $600 5 years ago at the Toyota dealer and the car is still running strong, although I drive a Infiniti G35 now .
2005 Infiniti G35X AWD Sedan
1999 Toyota Solara SLE V6
Old 07-29-2011, 01:10 PM   #15 (permalink)
Banned
View castelo2080's Photo Gallery
I'm having a same issue now. Thanks for the info
castelo2080 is offline   Reply With Quote
