Help! Trouble Starting 99 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2002, 02:33 PM   #1 (permalink)
View sabbates's Photo Gallery
I'm having trouble starting my 99 Camry when the engine is cold.
The engine will start up, then die right away unless I press the accelerator.
After it warms up a bit, it runs fine.
Anyone know what might be the problem?
Thanks
sabbates is offline   Reply With Quote
Old 09-30-2002, 07:06 PM   #2 (permalink)
View oibone781's Photo Gallery
same thing happened to mine, just went ahead and did a engine swap, caused to much trouble tryin to figure out what the problem was. Although what is causing yours might be different from what caused mine.
oibone781 is offline   Reply With Quote
Old 10-01-2002, 11:20 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Sounds like a problem with the IAC (idle air control) vavle. The IAC gets clogged with oil overtime and prevents the car from idling up on cold starts.
Its a common problem on the 5S-FE.
You can try cleaning it out with carb cleaner / throttle body cleaner and that will usually solve the problem.
"Skoolin' the unlearned!"
