Swapped battery terminals - now engine cranks but doesn't start...what have I broken? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2005, 07:38 AM   #1 (permalink)
View dolphan's Photo Gallery
Australia Swapped battery terminals - now engine cranks but doesn't start...what have I broken?
Hello all,
First post for me.
I own a 2000 Camry and accidently put in a battery the wrong way.
I know I have blown the 100A alternator fuse.
I have power to the fuses in the engine bay but not in the cabin.
The start cranks but the engine doesn't run.
I also have no dash lights working (except for door open and battery light).
No A/C or central locking either.
What can I check to repair the car and get it running?
Any help appreciated so I can double check what the mechanic does.
Matt
dolphan is offline   Reply With Quote
Old 08-17-2005, 07:46 AM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
replace alternator fuse.......secondly remeber...red is power and black is ground, car should start then. welcome to TN
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 08-17-2005, 08:08 AM   #3 (permalink)
Yeah I feel like the biggest idiot in the world
I should haven mentioned I shorted the two links together and no change. The start cranks but the engine won't run and no power as for my first message.
Am not sure what else to look at before concluding it is an ECU fault and going to the mechanics.
Matt
Old 08-17-2005, 08:20 AM   #4 (permalink)
Knailgun's Avatar
if memory serves me right, the part that isn't working is fuel related. you have a Gen3 I take it? if so, you can jump the leads on the diagnostic plug for a quick fix.....you'll need a haynes manual for me to walk you though this though. ONLY downside is if the accessory terminal is on....the fuel pump will be also....but it could save you a monster amount of $
Old 08-17-2005, 08:39 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Do gen 4s have fuses on the positive battery cable? If so check all those fuses.
Otherwise check the fuse box in the engine compartment (its on the side behind the battery) and the fuses inside the car.
"Skoolin' the unlearned!"
Old 08-18-2005, 09:27 AM   #6 (permalink)
Moving Forward
View Cyorke's Photo Gallery
DOnt they also have a fuseable link in the positive cable group. There is a small wire coming off of the positive battery terminal I think. If you blew that it wont start either if I rememebr right.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
