I guessed this topic already discussed in the past however, I still have problems on disable the DRL. I tried to removed the big fuse in the engine compartment for the DRL and the DRL was disabled. The problem is, the DRL is disabled which good, but I lost the HIGH BEAM as well. Is there any way that I can keep my HIGH BEAm without the DRL. PLEASE HELP>
This is my ride:
02 Camry SE V6, 18" tenzo wheels GT05, Eibach pro kit, DIY cold intake, DIY OEM X5 projectors retrofit w/ 4300k osram bulbs, alpine cda 9814, kenwood eq, fosgate amp, 2 fosgate 6x9, 2 eclipse 6x9, 1 10" mtx sub, and everything else stock
