Replaced PCV valve today - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2005, 11:50 PM   #1 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
Smile Replaced PCV valve today
I just put ina new PCV valve because i knew that it was already over due and because i want to get better MPG, so right after i replaced it i noticed that the engine idles a bit smoother. I want to know if any one that has replaced their valve on their 1MZ noticed a gain in gas mileage?
Thanx.
V6LE_CAMRY is offline   Reply With Quote
Old 08-18-2005, 07:13 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i replaced mine and then about 4 days later i went with bypassing it. still pulling about 20 mpg city with out that and a egr.
^ and leaving it that way!
Old 08-18-2005, 07:31 AM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
I take mine out and put it into a can, and soak it in paint thinner or brake cleaner. Shake it around and dry it off, and it is good as new!
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
Old 08-18-2005, 08:10 AM   #4 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
that's a pretty good idea..
skewe is offline   Reply With Quote
Old 08-18-2005, 10:46 AM   #5 (permalink)
Registered User
View qprint's Photo Gallery
Where is thre PCV valve located on the Camry V6 LE ?
Is it screwed in or pushed into a grommet ?
qprint is offline   Reply With Quote
Old 08-18-2005, 11:41 AM   #6 (permalink)
The Other White Meat
terrastrife's Avatar
no idea how to remove hte front one, but the rear one is the white bit of plastic the hose connects too.. the rear woul dbe most important, front isnt too crusical.
terrastrife is offline   Reply With Quote
Old 08-18-2005, 12:23 PM   #7 (permalink)
Registered User
I didnt know that there's 2 PCV valves
Old 08-18-2005, 12:57 PM   #8 (permalink)
V6LE_CAMRY's Avatar
Thres only one pcv valve, if the front one was a valve it would of been replaceable but thats just IMO
The PCV is located on the back valve cover it is on the passangers side and it is black whith a hose connected to it that goes to the intake manifold you only have to twist it a bit to get it out but you don't need any kind of tool. it costed me $ 3.99 at autozone. I think that it is worh the money if you are having a bad idle.
Old 08-18-2005, 02:08 PM   #9 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
alright, i know one end plugs in close to the passenger side near the intake mani, where does the other side go?
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 08-18-2005, 02:54 PM   #10 (permalink)
Retired VW Driver
View d0rkiishchris's Photo Gallery
yeah i have a 98 4 cyl and I thought the PCV valve was on top of the valve cover, theres another one?!
d0rkiishchris is offline   Reply With Quote
Old 08-18-2005, 03:14 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ The 4 cyl. (5S-FE), only has one PCV valve.
And yes its on the top of the valve cover.
"Skoolin' the unlearned!"
Old 08-18-2005, 03:30 PM   #12 (permalink)
Retired VW Driver
Me Scuzi
Old 08-22-2005, 12:15 PM   #13 (permalink)
Registered User
I rather clean it first with WD 40 and Throttle Body cleaner and replace it if I cant hear the clicking noice when shaking it
Old 08-22-2005, 03:38 PM   #14 (permalink)
View foompla's Photo Gallery
i wouldnt put plastic in any type of cleaner like thatpaint thinner. it makes it brittle and much more likely to crack. have a cellphone i used toyota fabric spot remover on as proof.
foompla is offline   Reply With Quote
Old 08-22-2005, 06:56 PM   #15 (permalink)
V6LE_CAMRY's Avatar
it's not worth cleaning them because they are so cheap. $3.99 at auto zone.
