well just to let you know, the first set, on the speedometer gauge, the cut out for the different warning lights is a little small so you will be partially covering the brake light indicator on the left.
the second set you need to line up to the stock gauges really well since the warning indicators need to be lined up perfectly for the light to shine through...
the installation is very simple, it took me about 30 minutes and i have no idea what im doing... the hardest part was taking the gauge cluster out and i did manage to break one of the tabs off...
i believe there was a post on how to install the gauges a while back...
im thinking about going back to stock or just replacing the bulbs with different colors... should i go with blue or would white look nice?
