99 Toyota Camry high/low beam Headlights
Hi, There.
I have a problem with my 99 Camry high/low beam.
I found no problem with bulbs, fuse, and wiring. So there is just switch left for the problem that I have no high/low beam headlights. No matter what I turn the nob in the switch , there is no change in headlights or no high beam.
Do I need change the whole headlight switch as it is quite expensive? Is this problem related to headlight dimmer switch? Can I just change that one?
Many thanks in advance.
John
