Change spark plug wires? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2005, 03:59 PM   #1 (permalink)
View jmp0126's Photo Gallery
3rd Generation Change spark plug wires?
Hi people,
I have a 95 Camry V6 LE. Next month I'll be getting the 60,000 mile tune up. I'll be putting in NGK plugs. Should I also change the stock plug wires to the NGK wires for performance wise or just leave the wires as is? Thanks for all your advise.
jmp0126
jmp0126 is offline   Reply With Quote
Old 08-18-2005, 04:22 PM   #2 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
Well, you should change the wire if you are doing a tune-up and probably for this spark plug change because why use a tired wireset on new plugs, right? As far as NGK or OEM, it's pretty much the same. They both are reliable and neither is a bad buy, so it's all about your wallet.
Lord_Anarchy is offline   Reply With Quote
Old 08-18-2005, 04:57 PM   #3 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
do the distributor rotor and distributor cap.
denso if you have $$
skewe is offline   Reply With Quote
Old 08-18-2005, 05:06 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $995375
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
stay with the OEM wires.
The Jedi Speeder at CarDomain
Old 08-18-2005, 10:56 PM   #5 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
I don't think he has one if he as the 1-MZ V6.
V6LE_CAMRY is offline   Reply With Quote
Old 08-18-2005, 11:33 PM   #6 (permalink)
93 Camry V-6 LE
View Camrylvr's Photo Gallery
That's right, if you have the 1MZ-FE engine then there is no distributor. It's a DIS (Distributorless Ignition Sytem). I think they use like 3 coil packs instead.
Camrylvr is offline   Reply With Quote
Old 08-18-2005, 11:36 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
http://www.sparkplugs.com <- Cheapest place for NGK plug wires that I found. Wires looked the same as my OEM wires except the blue color. The regular wires will do, no need to get the "high performance" ones.
2007 Camry 2.4L 5M
Old 08-19-2005, 09:57 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
you won't see any gains by using the more expensive wires. there are guys pushing 400hp with OEM plug wires...
