Help with Caliper painting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2005, 07:08 PM   #1 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $491868
View prnc_chrmng's Photo Gallery
so my FINALLY gettin around to painting my calipers.
my haynes maual says to plug the brake line with a the appropriate size rubber hose. anyone know what size hose that would be? i dont really feel like going out and buying random hose sizes.
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 08-19-2005, 08:21 PM   #2 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
when i painted my caliper, i ghettoed it. =/
i just covered the whole thing with newspaper and then sprayed brake cleaner to spray off the rotors if i got paint on them. works like a charm.
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 08-19-2005, 08:33 PM   #3 (permalink)
TN's Nikon Expert?
yeah, i was considering that, but im using an angle grinder with a wire brush to clean them.
if i get lazy ill ghetto it...
Old 08-19-2005, 08:46 PM   #4 (permalink)
The Cool Guy
the brake cleaner worked wonders because it dripped through around the rotors etc. and the paint just went down with it. but if the paint drys brake cleaner ain't gonna work. i can't take a picture for you yet of how mine look cuz my sister's camera fanaticism.
Old 08-19-2005, 08:50 PM   #5 (permalink)
View leasaunce's Photo Gallery
cover the are where you DON'T want to get spray paint, and it should take 30mins less on each caliper. do more than 3 coating for best result
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 08-19-2005, 08:58 PM   #6 (permalink)
The Cool Guy
yeah it doesn't take that long but i used a lot of paint though. lots of coats to make it even.
Old 08-19-2005, 10:41 PM   #7 (permalink)
TN's Nikon Expert?
yeah, but like i said, thats not what im trying to do. i dont wanna cover the area, id much rather take them off. if anyone knows another way plug that line, thatll work too
Old 08-19-2005, 10:43 PM   #8 (permalink)
The Other White Meat
terrastrife's Avatar
just degrease it, wash it let it dry get some paper and cover and spray .. unless ya gonna get it down to plishing smooth dont bother taking it off, hi temp paint is surprisingly sticky and covering.
terrastrife is offline   Reply With Quote
Old 08-20-2005, 04:44 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Forget plugging the brake line. You can't anyways, since it uses a banjo fitting.
Just unbolt the brake line from the caliper and let it drip into a pan.
Your going to have to bleed the brakes afterwards though.
"Skoolin' the unlearned!"
Old 08-20-2005, 11:49 AM   #10 (permalink)
Gameroom cash: $369176
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I was probably going to do this today....but I have no clue what color was suit best
RichieRichJP is offline   Reply With Quote
Old 08-20-2005, 11:59 AM   #11 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
try a ruler?
Hose is cheap, buy a foot of a few things that look the right size. If you're lucky, they'll let you return the stuff you don't use.
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 08-20-2005, 05:15 PM   #12 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
When i painted my calipers, dupri color had this kick ass kit that had brake cleaner in it along with caliper paint and a paint brush to put it on, that way u don't have to wory about covering everything up. And it looked very good once it's done.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Old 08-20-2005, 08:34 PM   #13 (permalink)
TN's Nikon Expert?
ok so i went to a couple auto parts store. then i saw a bunch of hoes at kregans, and after checking them out, i went inside and they had rolls of vacume hoses, i got a couple and it worked well enough that theres only one drop about every 10 minutes...so now im waiting for the paint to dry
Old 08-21-2005, 02:23 AM   #14 (permalink)
toot toot ahhhh beep beep
View cuttooth's Photo Gallery
you saw "a bunch of hoes" at kregans?
'02 is300, eShift, LSD
'94 toy pickup, 22re, 5spd, xtra cab
cuttooth is offline   Reply With Quote
Old 08-21-2005, 03:20 AM   #15 (permalink)
TN's Nikon Expert?
yes, yes i did. in fact thats why i stopped there in the first place.
