Installing Front Strut Tower Bar... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2005, 04:00 PM   #1 (permalink)
View Cammy4U2NV's Photo Gallery
i can't seem to get the bolts off to install my front strut tower bar on my gen 3...do i need to jack up the front end or anything special? i sprayed some u wrench it to try and loosen them up but that did work...and a wrench/ratchet weren't strong enough to torque the bolts off...any do this and have any tips for me?
Cammy4U2NV is offline   Reply With Quote
Old 08-21-2005, 04:04 PM   #2 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
They're just too tight.. just keep at it but don't force it.
You don't need to jack your car up.
CDub LXi is offline   Reply With Quote
Old 08-21-2005, 04:07 PM   #3 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
Do what I did. Wrench on, hit the wrench with a rubber mallet. Do not jack up your car, it needs the weight of the car to hold the strut in place.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 08-21-2005, 04:11 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
You are talking about the small nuts/bolts right?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-21-2005, 04:16 PM   #5 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
spray some wd-40 and do what redphoenix said
toyotaholic is offline   Reply With Quote
Old 08-21-2005, 04:26 PM   #6 (permalink)
alright...just spray WD-40 all over the nuts/bolts? and then attach the wrench and hit the wrench with a rubber mallet? how hard to hit it? just start wackin or controlled force?
Old 08-21-2005, 04:38 PM   #7 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
JUST DONT UNDO THE MIDDLE (BIG) ONE!!!!! its to the strut shaft itself!!
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 08-21-2005, 04:42 PM   #8 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
More like, the shock absorber top bolt.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 08-21-2005, 04:45 PM   #9 (permalink)
Gameroom cash: $369176
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Maybe try get a bar or pole and put it on the end of your wrench or whatever you're using for more torque.
RichieRichJP is offline   Reply With Quote
Old 08-21-2005, 04:58 PM   #10 (permalink)
N/A bites
Tercel GTS's Avatar
Gen3 camry's don't have shock absorbers, they have struts. And very correct, do not remove the middle nut!
雄のハヤブサ
Old 08-21-2005, 06:41 PM   #11 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
that's kind of strange the torque spec on those nuts are only like 20ft/lb
Old 08-21-2005, 07:22 PM   #12 (permalink)
VeeZed
Really?
My car has struts too...and a shock absorber that goes through the middle of the spring...isnt that the way Gen 3's have it? I would assume they some sort of shock absorber!!!
EDIT: *Googled it, and yep..sorry my mistake, the shock absorber is part of the strut assembly, much like the rear ST162 struts.
Old 08-21-2005, 07:46 PM   #13 (permalink)
Let us know how it it turns out as far as performance goes
Old 08-21-2005, 11:04 PM   #14 (permalink)
1993 Camry XLE
HoboJoe's Avatar
View HoboJoe's Photo Gallery
Where did you get it? I was thinking to steer clear of ebay, but I don't know.
HoboJoe is offline   Reply With Quote
Old 08-21-2005, 11:44 PM   #15 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Weird, on Gen 4, they're spec'd to 54 lb/ft IIRC...
How big a wrench are you using? I put a strut bar in my Camry and it was hell trying to do it with an 8" long 3/8" ratchet. When tightening them down with the ratchet, I was only able to torque the nuts to about 35 lb/ft before my hands really started to hurt so I don't imagine that you can put that much torque when trying to remove the nuts either.
I ended up using an impact wrench for removal and a torque wrench to finish tightening.
Do you have a cheater bar or anything else you can use? The rubber mallet is a good idea also. A 6 pt wrench or or socket will be best to avoid rounding the nut. If you use a wrench, use a box wrench instead of an open one if you have it.
2007 Camry 2.4L 5M
