Power window adjustments...HELP
MY 03 camry has a problem with the front power windows. If you try to put the windows to the "UP" position, using the window controls, the window goes to the top but never stops going, until you let off the control. It actuall bulges the door out sorta and makes a wind noise leak. If I tap the control to the "DOWN" position for a brief second, the window goes back down about an 1/8 of an inch and the noise from outside stops. Its as if the front windows are going up TOO HIGH> My rear windows stop when they hit the top. Is there an adjustment or something on the front ones to make the motor realize when its hit its travel limit or some such device??
