ACIS is plastic - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2005, 01:30 PM   #1 (permalink)
Registered User
View qprint's Photo Gallery
ACIS is plastic
My 2004 Camry V6 's ACIS is made of plastic. Has anyone removed this to get at the air control valve everyone is cleaning and grinding up ? The 10mm nuts are attached to bolts within the plastic, and I can see these stripping the plastic seat when I attempt to remove them. Even the intake plenum is black plastic. Need some info from you guys before I continue.
qprint is offline   Reply With Quote
Old 08-23-2005, 08:41 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
there is NO WAY its plastic... plastic would crack under the intake pressure in no time :P
might wanna take some pictures...
terrastrife is offline   Reply With Quote
Old 08-23-2005, 09:17 PM   #3 (permalink)
Registered User
Im not kidding
you. Look
http://www.toyotanation.com/photos/s...cat/500/page/1
Old 08-23-2005, 09:45 PM   #4 (permalink)
look slike a plastic cover OVER metal.
all cars these days have plastic covers, look i a lexus bay, you cant see any bit of metal at all.
if that is indeed plastic only, omg cries*
Old 08-23-2005, 11:04 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
There's no pressure in a Naturally Aspirated 1MZ-FE engine, Turbo's generate pressure (psi/etc.) NA's do not. In fact, it all operates under vacuum and with modern advances in formed plastic it can very easily withstand the heat and 'pressure' of an engine. The PT Cruiser, Half of Ford's product line (in fact they had a lawsuit settled recently about 'em), most current Honda's, The LS1 engine (The motor in many Vettes, Camaro's and Trans Am's) and many others utilize plastic intake manifolds. Being cheaper, and easier to mass produce (not to mention) lighter, there's every reason to make them out of plastic. Many ALSO have plastic covers, but those parts are not one and the same.
Now, as for whether or not the ACIS valve is plastic, I don't know. I've got the 1MZ with Metal parts
Old 08-23-2005, 11:20 PM   #6 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
yeah, ABS plastic is tough shit. The manifold on chevy trucks (5.3L I believe) is black plastic, and I've also heard of a lot of other cars having them. Not rare, and I wouldn't put it past a mfr to make the ACIS out of plastic too
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 08-23-2005, 11:26 PM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
Here's a write up on 'em.
http://www.itbgroup.com/pdf/AI2003_News_Release.pdf
Old 08-24-2005, 07:02 AM   #8 (permalink)
Registered User
Has anyone removed it to look, and clean the ACSI valve ?
Old 08-24-2005, 07:20 AM   #9 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
many
and most all of us has come back saying it's metal and where do i grind down
^ and leaving it that way!
Old 08-24-2005, 07:46 AM   #10 (permalink)
you could cut the whole thing off and tell us how it goes
Old 08-24-2005, 08:14 AM   #11 (permalink)
Registered User
I know many have removed the metal ACIS, but the nuts and bolts for this ABS type are different, almost designed to break if tampered with.
Has anyone removed the ABS plastic ACIS ?
Old 08-24-2005, 01:02 PM   #12 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
newer cars would utilize platic/ABS.. that's the new school.
As mentioned by somebody, cheaper, easier to mass produce and lighter.
skewe is offline   Reply With Quote
Old 08-25-2005, 12:05 PM   #13 (permalink)
Registered User
Would there be a gasket on this plastic ACIS ?
Old 08-25-2005, 01:25 PM   #14 (permalink)
skewe's Avatar
i assume yes
Old 08-26-2005, 11:37 AM   #15 (permalink)
Registered User
I guess no one has ever removed the ACIS on GEN 5 cars ?
