you may want to inspect the plugs and check the resistance of the wires, if thats gonna be applicaple. also, either a manual or auto, you should probable change the trans fluid and flush the coolant system one more time. maybe inspect the suspension for worn parts. perhaps replace the power steering fluid and bleed out the old brake fluid and bleed new fluid in. that should be a good start.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
