Clutch Pedal is verrry Squeaky when pressed/released - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2005, 07:08 PM   #1 (permalink)
5spd V6 ClrTail's Avatar
View 5spd V6 ClrTail's Photo Gallery
If i press the clutch, it squeaks, when i release it, it squeaks.
5spd V6 ClrTail is offline   Reply With Quote
Old 08-23-2005, 07:11 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397685
View RningOnFumes's Photo Gallery
have you tried wd-40 or another type of lubricant?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 08-23-2005, 07:13 PM   #3 (permalink)
I'll use it and see, but don't know where to actually apply it.
Old 08-23-2005, 07:50 PM   #4 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Apply it at the hinge of where the pedal swings in the bracket. If it doesn't stop, (mine didn't), remove the pedal arm from the bracket and lube it up with grease or something. I use PH/Zinc Oxide Grease, or you can use lithium. Worked a treat.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
