AC Cold for 30 mins and then not that cold anymore - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2005, 01:22 AM   #1 (permalink)
View ruoknow's Photo Gallery
Wink AC Cold for 30 mins and then not that cold anymore
Avalon sub-forum is too slow for technical questions. It seems like technically more experienced people like to drive a camry .
anyway, recently, my 96 avalon (90000 miles) developed a problem: the ac works very well at the beginning (blows cold air), but after about 30 mins, the air blown out is not that cold anymore (a little bit warm, but still lower than the temperature outside). At this time (not blowing cold), the AC switch is normal (not flashing). This sympton is very repeatable, no matter what speed i drive.
Anybody knows why?
ruoknow is offline   Reply With Quote
Old 08-24-2005, 01:38 AM   #2 (permalink)
View ffpmlex's Photo Gallery
Many vehicles have a built in feature where the A/C compressor automatically disengages to take the load off the engine so that it doesn't overheat. Since it occurs only after driving for a while, this could indeed be your problem, but it is a built in safety feature and is considered normal. The only thing you can do if this is the case is to make sure the engine is getting cooled efficiently...make sure your coolant is topped off and in good condition...make sure no leaks are present...make sure your engine oil level and quality are OK.
ffpmlex is offline   Reply With Quote
Old 08-24-2005, 01:55 AM   #3 (permalink)
[{} {}} =MR2 V6= {{} {}]
View Boostyle3VZ's Photo Gallery
expansion valve
Boostyle3VZ is offline   Reply With Quote
Old 08-24-2005, 01:56 AM   #4 (permalink)
Thanks ffpmlex.
when the car is doing that, the temperature gauge is quite normal.
Old 08-24-2005, 02:05 AM   #5 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
i agree with ffpmlex, make sure your your compressant is topped off, i think its R134. otherwise it would be a good idea to switch to this.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 08-24-2005, 02:42 AM   #6 (permalink)
The A/C compressor disengaging keeps the temperature normal!
Old 08-24-2005, 03:00 AM   #7 (permalink)
asm
View asm's Photo Gallery
Possible freeze at the expansion valve.
Freeze is usually cause by the moisture in the system. Of course, like someone else mentioned, it could just be the expansion valve is bad...
ASM
asm is offline   Reply With Quote
Old 08-24-2005, 06:05 AM   #8 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
Make sure your air switch is on "reciruculation" and not "outside air". This helps tremendously. Some american cars make this switch automatically when u turn on the air but not my camry.
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 08-24-2005, 06:31 AM   #9 (permalink)
View freestylez's Photo Gallery
yea if u turn on both buttons AC / Recirculation at the same time the AC will be cooooold, if i dont turn on the recirculation button my AC is warm as hell
2000 CAMRY CE
freestylez is offline   Reply With Quote
Old 08-24-2005, 07:41 AM   #10 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
I never put my A/C on recirculation... any smells in the car (food, cig smoke, etc) will stay in the car and over the course of years and years it'll stay in so you can smell it when you turn your A/C system on. The past 4 cars I've owned I didn't use the recirc function and never had a problem with proper cooling.
CDub LXi is offline   Reply With Quote
Old 08-24-2005, 09:25 AM   #11 (permalink)
thanks guys/gilrs. yes, i alway turn on the "recirculation" when i am using AC to get a more effeicient result. It still behaves like that. I think the problem may be associated with some switch or valve.
No body has the some problem as what i have?
Old 08-24-2005, 10:33 AM   #12 (permalink)
get a couple of cans of refrigerant might solve the problem then
2000 CAMRY CE
Old 08-24-2005, 11:19 AM   #13 (permalink)
View AdamS's Photo Gallery
(As mentioned previously) Your evaporator could be freezing up, on account of the faulty expansion valve. When it freezes up it does not allow air to flow through and be cooled. Do you notice a difference in airflow at all? Course it may not prevent airflow, but at times it does.
You really need someone to go over the system. Besides, the repair will require equipment that you more than likely do not have in your garage. You could just get someone to evacuate the system and then you could replace the part.
There is the potential that you have an insufficient amount of freon in the system. Have that checked, and you probably need a manifold gauge set to ge hooked up to properly diagnose the problem...
-Adam
1992 3VZ-FE with 218K
Check her out
AdamS is offline   Reply With Quote
Old 08-24-2005, 11:32 AM   #14 (permalink)
-Adam
The airflow keeps the same, while the only difference is temperature.
I am thinking if the evaporator is freezed up, that should be cold enough (cuz it's frozen, even without the circulation of R134a) to get a good ac.
The above conclusion could be wrong if a normally circulated AC system gives a temperature (at evaporator) way lower than a freezed one.
Old 08-24-2005, 11:41 AM   #15 (permalink)
^hmm, don't really know what you are saying...but it takes time for the evaporator to freeze over, and actually 30 minutes sounds about right. Usually the system will work perfectly, and then after a period of time it stops cooling altogether. If just the expansion valve is freezing up, then your freon will not pass through the evaporator and remove heat from the passing air.
Check her out
