Engine won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2005, 06:56 PM   #1 (permalink)
View weihsiuho@yahoo's Photo Gallery
Unhappy Engine won't start
I was replacing my battery in my 92 camry. After the new battery was installed, my car will not start again even when I jump start the car (I was able to do that with the old battery). The signal light would flash but the starter will not crank. What is the error message for signal light flashing? I check the fuse box, noticed the EFI (15amp) was blown and replace it but the car still will not crank. Does anybody has any idea what went wrong during my installations or can help me troubleshoot this?
Thanks
weihsiuho@yahoo is offline   Reply With Quote
Old 08-24-2005, 06:59 PM   #2 (permalink)
Me and my Bebe, Bianca
CamryPunk's Avatar
View CamryPunk's Photo Gallery
Check the ground cable.
Yukio Taira
-1992 4 door Bomex'ed out, Nitrous Express Sport'n, Rippmods SuperCharged Camry
-1992 4 Door EX Honda Civic 5 spd.
-2002 Subaru WRX Wagon... full JDM goodies. My new show car.
CamryPunk is offline   Reply With Quote
Old 08-24-2005, 08:38 PM   #3 (permalink)
Ground was connect (black). I can turn on the headlight but it is dim. The turn signal light kept flashing when I connected the positive cable.
Old 08-24-2005, 11:16 PM   #4 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
sounds like you jumped it wrong. definately get your alternator checked, could be shorting internally, lastly check ALL ground connections, have an aftermarket radio? the ground on that could also do it.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 08-25-2005, 12:16 AM   #5 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
Check the starter signal fuse inside the dashright to the left under the strering wheel. if it's o.k then the starter is a gonner too.
V6LE_CAMRY is offline   Reply With Quote
Old 08-25-2005, 09:37 AM   #6 (permalink)
Flagrant Fouler
Diehonda's Avatar
View Diehonda's Photo Gallery
check alternator, starter, battery cables connected fully, ground wire, fuses
Is there any sound when you crank the key? Clicking, humming, etc??
Free Gen 2 Camry book for anyone coming through Louisville, KY
Diehonda is offline   Reply With Quote
Old 08-25-2005, 09:55 AM   #7 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
did you connect the right wires to the right terminal.
red to red and black to black
skewe is offline   Reply With Quote
Old 08-25-2005, 10:32 AM   #8 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Gotta be something you did when you changed the battery. Trace back your steps. take it slow. Good luck.
mandyfig is offline   Reply With Quote
