All driving lights not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2005, 12:24 AM   #1 (permalink)
View camfan's Photo Gallery
I have a 2000 Camry and all four driving lights are not working. Brake lights and turn signals are working great. Does anyone have any ideas.
camfan is offline   Reply With Quote
Old 08-25-2005, 12:42 AM   #2 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
Chek the fuses in your dash and in the engine compartment. that should fix the problem.
V6LE_CAMRY is offline   Reply With Quote
Old 08-25-2005, 02:16 AM   #3 (permalink)
REAPER STRAIN's Avatar
View REAPER STRAIN's Photo Gallery
what do you mean by driving lights? Headlights? Corners? Please explain.
REAPER STRAIN is offline   Reply With Quote
Old 08-25-2005, 08:19 AM   #4 (permalink)
Headlights, brake lights and turn signals are working fine. It is the corner lights in front and driving lights in rear that are not working. Hope this helps Reaper Strain
Old 08-25-2005, 08:27 AM   #5 (permalink)
View freestylez's Photo Gallery
2000 CAMRY CE
freestylez is offline   Reply With Quote
Old 08-25-2005, 08:27 AM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
fuse and or relay...check chilton's manual...your oem manual may have it...doubtful though
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 08-25-2005, 08:49 AM   #7 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
I would put my $$ on the fuse.
u can also loook it up in ur car manual first, if not, get a haynes manual.
skewe is offline   Reply With Quote
Old 08-25-2005, 10:02 AM   #8 (permalink)
Moving Forward
View Cyorke's Photo Gallery
check the fuse and the bulbs. NOt likely that they would have all gone out at the same time but anything is possible. If one went out na dyou didnt replace it then the others are more likey to burn out quicker. Maybe one went out and you didnt notice it then the others started going also. More than likely it is the fuse though from the sounds of what you are describing. Check fuses under the dash and under the hood. the owners manual tells you waht each fuse controls. so jsut look for the one that matches the problem you are having.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 08-25-2005, 12:01 PM   #9 (permalink)
Yeah, sounds like a fuse. Check the running lamp fuses AND other fuses that deal with the lights too. You never know. Let us know what you find out.
Old 08-25-2005, 11:32 PM   #10 (permalink)
Problem fixed
Thanks for the input. Who says the internet isn't good.
I was a typical male and didn't look in the owners manual. It was the fuse under the dash.
Thanks
Old 08-26-2005, 11:19 AM   #11 (permalink)
skewe's Avatar
Thanks
cool..
glad u used the net..
p.s. manuals are my friend.
