Greddy emanage ultimate 4thgen V6 / 1gen V6 Solara
Anyone have this installed on their cars listed in the topic line? If so what voltage do have the ignition jumper (JP8) setting to? 5v system? or 12v system? We tried 5v no luck. Tried 12v no luck. I've got the GMU (g emanage ultimate) hooked up to the car but no luck starting the motor with the piggyback plugged in. Car starts without the GMU plugged in. What parameter settings need to be punched in just to get the car started? I've got the engine code and injector size info into the unit BTW. When we tried to start the motor we're getting no spark nor pulse from the injectors. Wiring hook up has many times to enusre proper fitting. What else could be wrong?
Rizal D.
Forever "tabasco"
99 V6 SE 5spd
http://members.cardomain.com/shidosha01
