Take the 1/2 inch drive ratchet (or breaker bar) and a 5 foot steel tube over it, and set the socket on the bolt and the end of the poll on the ground (if the pulley turnes clockwise (cause it's not a Honda) when you look at it, then lay the poll on to the right of the pulley).
Have one person cautiosly hold the ratchet/poll in place while the other person taps the ignition (not starting the car, just letting the starter ingage and then release).
If this is the first time the pulley has been taken off, then it should be on there with Toyota's specs and not some idiot tech who just wants to get the job done, so he uses a 600 lb. impact wrench! :x
Sorry.
Anyway, be VERY careful when you do this, and make sure each of the two people has common-sense. If this doesn't work you'll probably have to get some air tools somehow.
My car isn't old, it's aged to perfection.
1987 Camry, 3S-FE, 5-speed, white/maroon, 15" Konig, Kumho 712 rubber, KYB Gr-2, more to come...
