drilled or slotted - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2005, 11:07 AM   #1 (permalink)
Bad@$$
madmax3208's Avatar
View madmax3208's Photo Gallery
drilled or slotted
which are better slotted or drilled rotors?
I love my camry even tho its slow as hell
1996 Camry le 5sfe
tokico struts, whitline sway bar, ractive strut bar, weapon r intake, alpine cda9855( it was a 9821), idq 15, d5 300, d3 400, (seas 7" woofers, lpg tweets), and prolly the only cam with a cb radio
madmax3208 is offline   Reply With Quote
Old 08-27-2005, 12:03 PM   #2 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
IMO save your money, neither help.
If you are extremely hard on the brakes, you may want to consider getting them cryogenically treated.
http://www.policerotors.com/home_page.htm
IMO Raybestos PG Plus series rotors are excellent and very reasonably priced ($40 something per rotor for camry)
http://www.raybestos.com/usa/rotors.htm
If you do several 100mph to 0 stops as a regular part of your driving then you may want to consider a higher heat capable pad like the Axxis brand Ultimate or Metal Master (but keep in mind the one or two stops you do on a cold morning, you won't stop right away)
otherwise
The Hawk HPS are good performance pads
or
The OEM Akebono are not bad pads at all when coupled with a good rotor.
kenny1773 is offline   Reply With Quote
Old 08-27-2005, 12:41 PM   #3 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
try brembo rotors.
do a search about cross drilled, slotted or regular rotors. lots of good info there. it was about 4-5 months back in the camry forum
skewe is offline   Reply With Quote
Old 08-27-2005, 02:08 PM   #4 (permalink)
Bad@$$
madmax3208's Avatar
i was thinkin blank brembos w/ hawk ceramics
1996 Camry le 5sfe
Old 08-27-2005, 02:14 PM   #5 (permalink)
skewe's Avatar
blank brembos are definately in
i put some raybestos (not the cheap one) in on my 1993 camry and it works well.
no noise, little dust.
Old 08-27-2005, 02:15 PM   #6 (permalink)
Bad@$$
madmax3208's Avatar
so slotted and drilled rotors dont do much unless i do high speed braking and also what is the difference between composite and ceramic brake pads
1996 Camry le 5sfe
Old 08-27-2005, 02:55 PM   #7 (permalink)
skewe's Avatar
technically, it does not help in high speed breaking.
As there is less surface on slots or drilled rotors as opposed to regular rotors, it is not that effective in removing heat. The larger the surface, the faster heat dissipates.
it helps when there is a lot of water and those slots or drills will help remove water faster.
Besically, it is for WOW Factor.
FYI:
ebay cross drilled would wobble / warp faster than a non cross drilled.
Old 08-27-2005, 08:24 PM   #8 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Ahh..so thats why the likes of Porshe and Ferrari cross-drill and slot their rotors...wow factor! Duh..silly me!
I put DBA slotted rotors in my Gen 2, and noticed a big improvment in braking. She hauls up now!! Ask anyone who has ridden in my car :P
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 08-27-2005, 08:44 PM   #9 (permalink)
View leasaunce's Photo Gallery
how much does it costs for 1 pair of good big brakes?
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 08-27-2005, 08:52 PM   #10 (permalink)
tC
View 95camguy's Photo Gallery
i would stick with brembo blanks as others have said. however, if you must have something with alittle more bling then i would go with the drilled rotors over the slotted.
the reason is that slotted rotors tend to eat up pads much faster.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 08-27-2005, 08:58 PM   #11 (permalink)
skewe's Avatar
anywhere from US$100-$2400
Old 08-27-2005, 10:52 PM   #12 (permalink)
View D0UG's Photo Gallery
Much of the slotting and drilling is to lessen the weight of the rotors, not improve much if any on braking. Racers us cooling fans to cool the brakes and they also use "full metallic" pads - not composite or ceramic.
For street use, the slotting and drilling is for looks -- my opinion.
PS: Never, ever buy racing pads for street use. They do not work well at low speeds or when cold.
D0UG is offline   Reply With Quote
Old 08-27-2005, 10:57 PM   #13 (permalink)
Drilled rotors (in the case of Ferrari) are used for weight reduction. The same reason light weight performance cars also have holes drilled in the cluch and brake pedals. It is a super anal way to get rid of every last ounce of weight.
Slotted rotors actually slice the pad a bit to prevent glazing. Unless you ride your brakes, there is no need for these and preventing glazing is not a performance increase.
In all honesty, if you can lock your brakes (without ABS), they have plenty of stopping power and you have no need to increase stopping power at that point. If you can make the ABS activate on a dry road, then the same applies.
What higher end braking products can buy you is heat tolerance and modulation (for example: race pads will resist fading more than standard one as they are designed to work in a higher heat range. higher friction ratings on pads can help with modulation, a higher friction pad will grip faster, make your wheels lock up faster with less pressure on the brake pedal).
All factory braking systems I have seen have enough power to lock the wheels (or engage ABS) on a dry road if you stand on them.
If you want to stop better, install a sticky tire that will grip the road better. If your tires can grip more before they lock up, you will stop faster.
If your problem is brake fade, then high performance pads may help you as they can tolerate heat better. Drilled and slotted rotors have a lower thernal capacity than an exact rotor without the drilling/slotting. You want the highest thermal capcity possible to resist fade.
If your problem is that you warp rotors quickly, maybe the cryogenic are the way to go or if you want to spend $2000 a big brake kit with a larger rotor that has a higher thermal capacity (not worth the money in most cases IMO)
A good quality rotor made from a quality steel is all you need (this eliminates the chinese made rotors on ebay ) Brembo does make some good blanks, but IMO you pay to much simply for the name. This is why I recomend Raybestos.
Pads are another story - you have to watch compounds and heat ranges that they perform in and buy the ones that suit your driving. The high end race track pad often sucks on the street. Get the right tool for the job
Bottom line is there are zero performance advantages to slotted and drilled for a street car only negatives and an asthetic appeal mostly to those who do not realize the negatives. All companies that sell rotors will play on misinformation to make a buck.
Old 08-27-2005, 11:27 PM   #14 (permalink)
VeeZed
So your saying, that they will drill minute amounts out of the disc rotors to reduce a cars weight...and yet..have a full fledged interior trim, badges, stereo etc etc..
Old 08-27-2005, 11:44 PM   #15 (permalink)
5sp 3VZ-FE
mescalito's Avatar
View mescalito's Photo Gallery
^ they DO serve a purpose, its just not applicable to everyone.
they wouldn't be in such wide use if there was no purpose - and the car manufacturers would go back to full rotors...drilled rotors on a 911 turbo yes, on a camry? no
mescalito is offline   Reply With Quote
