Tachometer Installation... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2005, 01:32 AM   #1 (permalink)
ApexiCamry
View DiscoPotato's Photo Gallery
2nd Generation Tachometer Installation...
Hello guys, I have a 2nd gen. 1990 Camry 4cyl. It did't come with a tachometer so I bought one. It's called a Sunpro sun super tach II. Has anyone here installed one in their Camry? Where should I connect the green wire for the tach? Can anyone show me how to install it with pictures? Thanks for the help...
DiscoPotato is offline   Reply With Quote
Old 08-29-2005, 01:56 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The tach wire can be found in several different places.
1. One of the plugs that plugs into the back of the gauge cluster.
2. Black wire on ignitor. The ignitor is next to the battery, on the left side.
3. Check connector on top of distributor.
Wiring diagrams for guage cluster. Tach wire is labeled:
Page 1
Page 2
"Skoolin' the unlearned!"
Old 08-29-2005, 02:02 AM   #3 (permalink)
ApexiCamry
Thank you very much. You are awesome!
Old 08-29-2005, 01:23 PM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
or u could of went to the junkyard and bought a cluster with a tach from another gen2 camry and used that
Old 08-29-2005, 06:18 PM   #5 (permalink)
ApexiCamry
Ooohh... I see. The tach was cheap though and I dont know any junkyards here in my place.
Old 08-30-2005, 02:22 AM   #6 (permalink)
ApexiCamry
Sorry guys but I'm stuck... Do i have to remove the dashboard to connect the wires and how can i do that? im also not sure which wire to connect... Im so new to this, really sorry if im being a newb but i am.
Old 08-30-2005, 03:40 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
http://www.sunpro.com/publish/2004/0...lish_16327.pdf
Black = ground
Red = switched +12V source (ie: ignition)
White = wire to parking light wire
Green = tach wire
Parking light wire can be found on a plug behind the guage cluster.
^ Green wire (2nd from left) in the plug above.
Ignition can be found at the harness at the bottom of the steering column. Its a black wire with yellow stripe.
Old 08-31-2005, 03:23 PM   #8 (permalink)
ApexiCamry
Can you pls show me a pic of where I can connect the tach wire and how am i going to route the wire?
Old 08-31-2005, 03:55 PM   #9 (permalink)
The Other White Meat
terrastrife's Avatar
ground -- sigh, closest bit of car metal...
terrastrife is offline   Reply With Quote
Old 08-31-2005, 05:42 PM   #10 (permalink)
ApexiCamry
I see!
Old 08-31-2005, 06:00 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
The tach wire is on one of the plugs behind the gauge cluster. Its at the same place you would find the parking light wire.
Theres 3 plugs that plug into the back of the gauge cluster. Just look for a black wire on a 8 pin plug.
How you route the wires depends on where you mount the tach. You know where the wires need to go, so route the wires from the tach to wherever they need to go.
Old 08-31-2005, 06:58 PM   #12 (permalink)
ApexiCamry
This applies to a gauge cluster without a tach right?
Old 08-31-2005, 07:08 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
^ Yes.
The gauge cluster wiring is the same, regardless if your gauge cluster has a tach or not.
Thats why you can get a stock gauge cluster that has a tach, plug it in, and it'll work.
Old 08-31-2005, 07:19 PM   #14 (permalink)
ApexiCamry
OOoohh... I see! Thanks a whole lot 88LE, you are the awesom-est!
Old 09-01-2005, 04:16 PM   #15 (permalink)
ApexiCamry
My new tachometer is so awesome! I can't stop looking at the needle go up and down. It looks so clean and cool. Finally, my car has a tach. Thanks everyone, specially 88 LE.
