question about a light weight flywheel for 3s-fe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2002, 05:35 AM   #1 (permalink)
Gen 2 Pimp
phat91camryLE's Avatar
View phat91camryLE's Photo Gallery
I found a light weight flywheel for the 3S-FE engine...What advantages come with with a lighter flywheel if any... would it be worth it?
thanks
phat91camryLE is offline   Reply With Quote
Old 10-07-2002, 06:36 AM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
The advantage is having less weight for the crank to spin around so you are not losing as much power when you are transfering the power to the wheels. However your idle will be a rough one because it is lighter. You can not get the light weight flywheel with a car that is an automatic. the automatic uses a flexplate not a flywheel.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 10-07-2002, 01:41 PM   #3 (permalink)
Gen 2 Pimp
thanks man
