access panel - headunit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2005, 05:52 PM   #1 (permalink)
LeArNinG sTatUs...
trueasiatic's Avatar
View trueasiatic's Photo Gallery
Gen5 access panel - headunit
does any body who has a gen 5 replaced there H/U? if so... did you took it out yourself? coz i just wanna know how to take of the panel, ive been trying to take it off but unfortunately the only part that is loose enough it the top part of the panel, is there any screws that is holding it?
Thanks.
PIONEER PREMIER DEH-P8MP/// ROCKFORD FOSGATE T20001BD/// ROCKFORD FOSGATE P4004/// ROCKFORD FOSGATE 3X12 POWER T1's/// INFINITY KAPPA 60.5cs - KAPPA 693.7i/// SUBZONE SEALED ENCLOSURE///EdEAD V1SE
trueasiatic is offline   Reply With Quote
Old 08-30-2005, 06:34 PM   #2 (permalink)
Fixing My Jet
Gameroom cash: $101050
View Meperezs's Photo Gallery
u have to pop out the top part (with the air vents) and then take out the climate controls. No scews on either just snpas/clips on them. I used a flat head to pop off the top and hten just pulled out the bottom by hand. The H/U is bolted on once u get all that off. Hope I could help.
If you can read this thank a teacher. If you can read this in English thank an Airman.
Meperezs is offline   Reply With Quote
Old 08-31-2005, 09:23 PM   #3 (permalink)
LeArNinG sTatUs...
i tried taking off the top part but the ones on the bottom is kicking my a$$ , do i have to use the flat screw driver to pry it? or do i have to take out the climate control first? and for the front speakers what size are those? Thanks again.
Old 08-31-2005, 10:59 PM   #4 (permalink)
Banned
modifierLE's Avatar
View modifierLE's Photo Gallery
Gen5
You need to remove the bottom pannel first (the one with air conditioning/heat controls) Try prying from the top corners first and then at the bottom it should come out real easy. Then remove the top, pull the top off from the bottom with your hands. I have put 3 HU into my car and i have no problem. Do you have digital or analog climate controls?
modifierLE is offline   Reply With Quote
Old 09-01-2005, 12:45 AM   #5 (permalink)
LeArNinG sTatUs...
The top comes off easily but the buttom part still having problem with it... Don't know where to pry it... Don't want my panel to get chipped when prying it so any suggestions? I have the dial/analog climate control.
Old 09-01-2005, 12:48 AM   #6 (permalink)
Banned
modifierLE's Avatar
The First time i took the panels off they were really tough to take off cause the clips were brand new. Dont be afraid of using a little force to pry it out. But it should come right out. And it is weird that you can get the top panel off without the bottom one coming out first.. The top panel has a lip going along the bottom of it that locks into the bottom control panel
Old 09-04-2005, 11:04 AM   #7 (permalink)
LeArNinG sTatUs...
wuhoo!!! thanks for the help man, i got my H/U replaced, im loving my new system.
