My transmission is pissing me off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2005, 09:46 AM   #1 (permalink)
1B2 V6 Clean!
Camon19z's Avatar
View Camon19z's Photo Gallery
4th Generation My transmission is pissing me off
ok from a cold start into reverse is no problem, but when the car is warm and i switch into reverse i not only feel it jerk i hear a thunp noise from the engine bay, i dont what it is or how to stop it. If anyone had the same problem please tell how to fix it, hopefully its not a mount or anything.
Camon19z is offline   Reply With Quote
Old 08-31-2005, 12:27 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
if it were a mount, you'd hear the sound all the time, not just when the engine was cold. you may want to inspect your mounts though just to be safe. on a far note, it could have to do with line pressure. being that when the trans fluid is cold, you get a good amount of line pressure, more so than say when its hot. now, when its cold, you may be getting thicker fluid through the trans and it may be the right amount of pressure. however when the fluid is warm, it is thinner and you are not getting enough pressure. and when it finally goes into gear, its a little starved of fluid and causes the trans to rock a tad and when that hapens, it may move your engine and trans onthe mounts. that could be a suggestion.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-31-2005, 12:49 PM   #3 (permalink)
that guy
View xylium's Photo Gallery
Sounds like a mount to me.
Totally stock 00' 4cyl in Sage. Looking for set of nice stock 15" alloys for cheap, got any?
xylium is offline   Reply With Quote
Old 08-31-2005, 01:52 PM   #4 (permalink)
1B2 V6 Clean!
Camon19z's Avatar
is it normal to change the mounts at 97k. And if it is the mount does it make sense to change one?
Old 08-31-2005, 01:55 PM   #5 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
FYI: there are transmission mounts as well, i remember when i mentioned mounts to someone they went ahead and change engine mounts (to which nothing was affected)
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 08-31-2005, 03:48 PM   #6 (permalink)
View peanutbutter's Photo Gallery
Rubber expands when cold, shrinks when hot.
peanutbutter is offline   Reply With Quote
Old 08-31-2005, 03:54 PM   #7 (permalink)
The Other White Meat
terrastrife's Avatar
so rubber defies (basic) laws of physics hey?
its probably either front or tranny mount.
terrastrife is offline   Reply With Quote
Old 08-31-2005, 04:06 PM   #8 (permalink)
Below point of freezing it expands, example mechanics freeze rear main seals so they fit over the crank easier.
Old 08-31-2005, 08:56 PM   #9 (permalink)
View Toyteq's Photo Gallery
huh?
I have never seen this ....and I do this daily.
Toyteq is offline   Reply With Quote
Old 08-31-2005, 09:46 PM   #10 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
change your tranny fluid. preferably a pan drop.
V6LE_CAMRY is offline   Reply With Quote
Old 08-31-2005, 09:50 PM   #11 (permalink)
1B2 V6 Clean!
Camon19z's Avatar
just changed the tranny oil. umm i think i might just get it flushed first before i look into the tranny mounts.
Old 08-31-2005, 10:23 PM   #12 (permalink)
V6LE_CAMRY's Avatar
maybe you race it too much with your son.
Old 08-31-2005, 10:53 PM   #13 (permalink)
1B2 V6 Clean!
Camon19z's Avatar
no racing for me, just moddig for mor horses.
Old 09-01-2005, 12:38 AM   #14 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
lemme clear that up a bit. when cold, rubber is more harder, thus making it less flexible.
when rubber is hot, it is more soft and more flexible, hence letting it bend more freely and easily. hence the expand/shrink feeling...
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
