Camry Reading Light Mod - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2005, 12:36 PM   #1 (permalink)
View jjakubowski's Photo Gallery
I have a 2005 Camry SE, and I noticed that when you open the doors only the dome light comes on. Now I also have a 2004 Sienna Limited and when one of the front doors are opened the reading lights come on.
Here is my question, Does anyone know or have experince modifying the Camry reading lights to turn on with the dome light when the doors are opened?
I am also thinking about adding interior lights under the dash and under the seats to light up the floor. Any thoughts or ideas here?
In my Sienna I changed all interior lights out and replaced them with LED lights that give a brighter blue hue. Let me know if you are interested in information on the LEDs that I used, I just ordered the replacement LEDs for my Camry.
jjakubowski is offline   Reply With Quote
Old 08-31-2005, 12:48 PM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Hehe, I've replaced all of mine with LEDs as well. If you want your map lights to turn on with the dome light when you open the door, all you have to do is splice the map light wires into the dome light wires. However, I THINK (someone correct me if I'm wrong) that you might be losing function of the maplights as far as using them once the doors are closed unless you turned on the dome light.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 08-31-2005, 12:54 PM   #3 (permalink)
That is what I was thinking but I do not want to mess with the functionality of the reading lihgts.
I would be interesed in the LEDs that you use, just to make sure I did not pay too much and that I am using the right ones.
Old 08-31-2005, 01:00 PM   #4 (permalink)
HID/Retrofit Expert
I got mine from www.superlumination.com The 194s in the license plate bulbs and map lights were the 4-LED ones. The dome light was the 6-LED 3175 bulb.
Old 08-31-2005, 05:43 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You'd have to do some rewiring.
The dome light works off a negative trigger. In other words the negative is switched.
Rewire the reading lights into the dome light circuit.
http://www.toyotanation.com/forum/t94355.html
http://toyotanation.com/forum/t93063.html
"Skoolin' the unlearned!"
Old 08-31-2005, 06:15 PM   #6 (permalink)
2005 Camry XLE V6
View 05CamryGuy's Photo Gallery
Is this what you're thinking of doing?
I placed LEDs on the bottom of each seat, two facing forward and two facing back. Also have white LEDs inside the center console box for illumination at night (so I can see what's in there when I open up the lid). The floor LEDs are powerd by the 12V source in the center arm rest, the console box LEDs are powered by the 12V source next to the seat heater.
2012 Lexus RX350 Luxury Pkg w/Nav + HUD, ML & PA
2010 Lexus IS250 AWD w/Nav
2007 Lexus ES350 Ultra Luxury w/Nav, ML & PA
2007 Camry XLE V6
2005 Camry XLE V6
05CamryGuy is offline   Reply With Quote
Old 08-31-2005, 08:29 PM   #7 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
why do leds when you can do 12inch cathodes or neons?
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 08-31-2005, 10:31 PM   #8 (permalink)
2005 Camry XLE V6
LEDs take less power, less space so you can put them just about anywhere, cheaper (for me), and last just about the life of your car.
I am equally satisfied with the job done by a 1/4" LED in place of a 12" neon.
2007 Camry XLE V6
2005 Camry XLE V6
Old 08-31-2005, 10:51 PM   #9 (permalink)
PBM
Boob
View PBM's Photo Gallery
i am satisfied with the cathodes installed in my car.
i had white in there before and they were also bright and lit just as well but i decided to do a mostly cosmetic blue color since i rarely find a need to see anythinga round my feet in real color. cathodes are well worth the price i think. 30,000 hour lifespan and they don't draw much power either.
PBM is offline   Reply With Quote
Old 08-31-2005, 10:59 PM   #10 (permalink)
How Ya Like Me Now?
yea they barely draw any power, are cheap and easy to install. pluss they give out tons of light which is wide focused which i think works better for the app. i like the led in the dash pocket tho
98 V6 XLE
Old 09-01-2005, 12:04 AM   #11 (permalink)
Great ideas guys, keep them comming...
05CamryGuy, what about the dash lights? what did you do to make them blue, instead of the factory orange?
Old 09-01-2005, 12:15 AM   #12 (permalink)
Will this rewiring require any removal of the header panel? Are there any wires that can be tapped into behind the reading lights or are they routed behind the sun roof?
Thanks for your help...
Old 09-01-2005, 12:18 AM   #13 (permalink)
How Ya Like Me Now?
the wire for the door trigger is in the fuse panel. but if you were looking to make the reading lights function as a dome light you could prolly rig something up using a relay etc.
btw
CO represent
98 V6 XLE
Old 09-01-2005, 05:14 PM   #14 (permalink)
2005 Camry XLE V6
By dash lights you mean the guages right? No, my dash lights are the way they came OEM. Mine are red on white optitron meters, I think the SE models have orange gauges - mine is XLE. I kinda like them, I'm in no hurry to replace those
2007 Camry XLE V6
2005 Camry XLE V6
Old 07-02-2006, 06:34 PM   #15 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
Gen5
Is there a limit on how many things you can power with the 12V sources? I read people talking like there are no risks involved and endless possibilities.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
