Stalling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2005, 06:31 PM   #1 (permalink)
CLEAN Camry
sk8chip98's Avatar
View sk8chip98's Photo Gallery
3rd Generation Stalling
I drive a 95 5SFE and its stalling now. I put gas in it the other day from a shaddy station and i think it had water in it. I'll be driving along with no problems and stop at a light and it will sit there with no problems then out of no where it starts to sputter and idel ruff. Anyone got any ideas on what to do?....
sk8chip98 is offline   Reply With Quote
Old 08-31-2005, 07:01 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
me: clean IAC
you: what?
me: search.
terrastrife is offline   Reply With Quote
Old 08-31-2005, 07:08 PM   #3 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
That gas might od been bad. or your fuel filter clouged up. Try changing that and check your MAS (Mass Air Flow) sensor. Its located on the intake tube rigth by the air filter housing and also check that your fuel pump is working.
V6LE_CAMRY is offline   Reply With Quote
Old 08-31-2005, 07:18 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ He has a 5S-FE, which uses a MAP (manifold absolute pressure) sensor.
Theres no MAF, MAS, AFM, whatever you wanna call it.
"Skoolin' the unlearned!"
Old 08-31-2005, 08:46 PM   #5 (permalink)
View Toyteq's Photo Gallery
Disconnect the fuel line and pump with the fuel pump (key on) all the fuel out into a clear container and start there. If it was not doing it before the fill up...then that should tell you something. Do not worry about the filter yet. Get some good gas in it and see what it does. The IAC could be carboned up but start with the fuel since this is when you noticed it.
Toyteq is offline   Reply With Quote
Old 09-01-2005, 09:54 AM   #6 (permalink)
CLEAN Camry
sk8chip98's Avatar
yeah i think im going to empty out the tank and see if there is any water in it. Thanks alot guys ill post up when i figure out what the deal is.
Old 09-02-2005, 01:11 PM   #7 (permalink)
Gameroom cash: $304455
This is one area where Heet or some similar water absorbing additive actually does work. I would get a couple of cans of the stuff and pour botj cans in the tank and just drive it for a while. It may take care of the water, if that is the problem. If not, then you could try emptying the tank. Just my 2 cents.
Mike
Old 09-02-2005, 01:21 PM   #8 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
Just give her gas as you slowly let the clutch out, and she won't stall.
Haha jk.
Yeah could be bad gas, contaminated with either water or sediment. After you get stuff figured out, a new fuel filter might be a great idea.
Keep is offline   Reply With Quote
