Radiator Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2002, 05:12 PM   #1 (permalink)
View OU8MYDUST's Photo Gallery
Radiator Help!
I just need to know if the radiator on a gen3 4cyl is a double or single fin?
SHOW + GO = GTO
OU8MYDUST is offline   Reply With Quote
Old 10-09-2002, 05:51 PM   #2 (permalink)
Really though I need to know. I need to replace my old one because its all worn out and rusted. The place I order parts from needs to now if I need a single or double fin?? It doesn't say in manual, does anyone know?? :-?
SHOW + GO = GTO
Old 10-12-2002, 06:19 PM   #3 (permalink)
Anyone know how to re-place the radiator? :-?
BTW: What are your thoughts on rebuilt parts?
SHOW + GO = GTO
Old 10-13-2002, 10:50 AM   #4 (permalink)
View cmrygrl94's Photo Gallery
I have a V6 and i had to replace my radiator two weeks ago cuz i had a small hole in the radiator core. I am not sure if the set up for the radiator is the same for the 4cy and the V6. First remove the upper hose. Then u need to remove the hold downs for the radiator and shroud. My radiator fan is powered by power steering fluid so i had to remove the power streeting hose that ran in to the radiator fan motor. then i had to remove the hose coming out of the fan. Once i had that removed i could remove the fan shourd (which is held in place by 4 bolts). With that off i disconnected the lower radiator hose from the radiator. Then i disconnected the transmission lines going in to the radiator. Once all that is off all u have to do is pull out the radiator. It wasn't that bad the only thing is that it was really messy and i lost alot of fluids ie. coolant, transmission fluid, and powersteering fluid. Good luck. If ur good with cars its not something u should struggle with.
Elaine
Who says girls don't know their sh*t...
94 1MZFE
cmrygrl94 is offline   Reply With Quote
