loose plug, where does it go (56k maybe) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2005, 03:09 PM   #1 (permalink)
permanent hiatus
ryuji16's Avatar
View ryuji16's Photo Gallery
theres a loose plug on my 3vz fe:
theres a wire loomed in the same tube with this sensor. this sensor is located very closeby the oil filter (the filter is just to the right of it).
the loose plug in question is circled on the bottom of the picture, and the wire for this plug looms in with the aforementioned sensor and goes off somewhere.
heres a closeup of the plug, pardon the blur:
so... any ideas what this might be? i looked around and couldnt find its mate anywhere. please save this lonely plug.
thx
three liters est. 1992
1.5 liters est. 2006
ryuji16 is offline   Reply With Quote
Old 09-03-2005, 03:16 PM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
that is the oil pressure switch.
the plug that goes to nothing is for an oil LEVEL sensor which only comes on the 3vz that is in the lexus es300... that is located on the oil pan on that 3vz. you dont have it, so dont worry, be happy.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 09-03-2005, 03:21 PM   #3 (permalink)
permanent hiatus
ryuji16's Avatar
ah, ic. thank you very much
Old 09-03-2005, 03:23 PM   #4 (permalink)
permanent hiatus
ryuji16's Avatar
but wait, so how would i know if there was a problem and that i was low on oil?
Old 09-03-2005, 09:44 PM   #5 (permalink)
PBM
Boob
View PBM's Photo Gallery
Toyotas and most car manufacturers have this built in feature where if your car is low on oil, it will overheat to let you know or maybe it will even seize up to prevent you from driving anywhere unsafely. = P
PBM is offline   Reply With Quote
Old 09-03-2005, 10:45 PM   #6 (permalink)
I'm a Mac
zoni's Avatar
it generally will be fine... you will know if you NEED to check your oil level regularly if you start to see low levels when you change the oil.
just check periodically.
Dave Zoni
Old 09-05-2005, 12:27 PM   #7 (permalink)
View deekay140's Photo Gallery
that oil pressure switch is a single blade connector, the one you have circled is unused
deekay140 is offline   Reply With Quote
Old 09-05-2005, 01:35 PM   #8 (permalink)
I'm a Mac
zoni's Avatar
really, you sure? we havent already established that.....
Dave Zoni
Old 09-05-2005, 08:47 PM   #9 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
^ clownin
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
