Cel? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2005, 11:21 PM   #1 (permalink)
View sandman81's Photo Gallery
Unhappy Cel?
well my camry gave me a check engine light today. my antifreze was very low so i added some more and cleared my codes. an hr later the code still hasnt come back. have i fixed it? will low antifreze set off a CEL code? please help
sandman81 is offline   Reply With Quote
Old 09-03-2005, 11:23 PM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
CEL comes on for many reasons. u might have fixed it..
next time, take it to autozone for a free check...
skewe is offline   Reply With Quote
Old 09-03-2005, 11:29 PM   #3 (permalink)
thanks skewe. is it possible though that low antifreze would set this off?
Old 09-04-2005, 01:17 PM   #4 (permalink)
Gameroom cash: $304455
You don't specify the year of your car so we can't tell whether it is OBD1 or OBD2. If your car is 96 or newer, it is OBD2. If the check engine light comes back on do as skewe suggested and take it to Autozone to have the code read. If it is 96 or newer the code is probably still in it's OBD2 memory. Take it to Autozone anyway and have it read. No reason to guess what caused it.
In addition, cars do not comsume coolant. If you were low you have a leak somewhere. It is best to have it looked at by someone who can pressure test the system or use a dye to find the leak. In the mean time keep checking the coolant level while the engine is cold and top off as necessary with a 50/50 mix of antifreeze and water. You do not want to overheat the engine. Today's engines with aluminum cylinder heads do not take too well to overheating.
Mike
Old 09-05-2005, 12:20 PM   #5 (permalink)
View deekay140's Photo Gallery
antifreeze has nothing to do with it.
deekay140 is offline   Reply With Quote
