Ignition Fuse Help Please.....
I need some suggestions please.. I have a 92 camry, 4- cyl. The battery went dead, so I replaced it. The next day it quit while running. Every time I turn the key to the "on"
position, not starting, I blow the "AM2" ignition fuse which is a 30 amp fusein the ignition circuit.. I looked for a short in the battery cables, nothing. I replaced the internal ignition coil, cap, and rotor button, and the ignition switch. I checked the EFI relay and it works fine. I unplugged the fuel pump and still blew a fuse. I unplugged the wiring to the ignition coil and I didn't blow the fuse, that's why I replaced the ignition switch. Any suggestions would be very appreciated. Thanks.
