Hope everyone had a fun & safe Labor Day. Anyway my question is this. My stock rims are 15 x 6 with tire size 205/65r/15. When it's time to replace the struts on my 95 Camry V6 LE I was thinking of putting on new springs at the same time. By keeping the stock wheels, will the fender and tires scrape if I buy Eibach springs which will lower the car 1 inch.
I do not want to buy bigger rims b/c I like the looks of the stock rims. Thanks all for your opinion.
with stock rims, any drop will be okay....only when you get aftermarket rims that are wider and with a different offset that you have to worry about rubbing
and sagging? potentially....yes....but it will take a number of years
if you want a lower drop and better quality than intrax, then go h&r....
and if you have a v6, then you have even more options - the 4banger eibachs will give you a lower drop than advertised, and so will the 4banger h&r springs
HaHa
"Life is a deep sleep, of which love is the dream..." Ripped...and the girls are loving it.
the i4 front though will drop a v6 lower at the front by about 1/2"
youll probably start bottoming out on everything, camrys dont need kits to be physically low.
drive carefully.
Alright, well will they still be as safe and last as long.
yes.
I am currently running the i4 eibachs on my v6 camry....I started out with the v6 springs, but was then unhappy with the drop, so then picked up some i4 springs and installed the fronts for (as terrastrife said) the extra 1/2 inch in the front- makes a subtle but important difference
but no trouble with bottoming out, though as terrastrife also said, the frame of the gen3 hangs a lot lower than you can see....you basically get the h&r type of drop with eibach quality springs
HaHa
